996 : 1997-2005 48
993 : 1993-1998 6
964 : 1989-1993 5
Boxster : 1997- 14
Cayenne : 2003- 8
Macan : 2014- 3
912-914-924-928-944-968 4
Stuart
2004 Porsche 996 GT3 Mk2
PostPosted: Thu Jun 19, 2008 9:52 pm    Post subject: GT3 console delete install DIY Reply with quote
This is from Rockit's install gallery on Rennlist, all credit is to him for the instructions.
oh, b@lls, preview is back to front then actual post, ok, not typing again, you'll have to read from bottom up, pretend you're Aussie or something...and there's no step 1 before anyone points it out Cool
additional info:
step 10 - This is the bracket removed. The holes on both sides, closest to you from this view is where the floor mounting bolts went through. This is the set of bolts that the mounting tabs in the carpeting delete unit will slide over. Use the same nuts to affix the unit to the floor. One note: You will need to use a 1/4" drill to re-drill the mounting tabs of the delete unit in order for them to slide over the floor mounting bolts. The holes drilled at the factory are too small for some reason.
Stuart
PostPosted: Thu Jun 19, 2008 9:58 pm    Post subject: Reply with quote
additional info:
step 7 - This view shows the console's front mounting bracket after the console has been removed(place shift in 2nd gear to pull console out). To remove the console, pull both sides off(attached by clips) and remove the torx screws(two per side). On each side, one screw attaches it to front bracket, one to the rear bracket. Repeat process on the other side.***Note: There is one more torx screw that needs to be removed that is located just below the front edge of the shifter boot in order to lift up the (main) lower center console.***
step 8 - This view shows the shifter bag disconnected from the lower center console. Use a credit card or the like and slide it under the metal bag ring and carefully pop the bag off from it's mounting point. Use a 10 mm flat crescent wrench to remove the nuts that affix the bracket to the mounting bolts on the floor(2 per side).
911UK
Porsche Community
Porsche Community
1997 Porsche 993 Carrera 2
PostPosted: Thu Jun 19, 2008 10:35 pm    Post subject: Re: GT3 console delete install DIY Reply with quote
Great work there Stuart Thumb
Will add that to the GT3 FAQ if thats OK !
Whoops, my bad ! wack switched it around today from what it was after some feedback to make it easier !
i.e. the attachment order loaded in is the order it appears instead of the 1st attachment is the last one displayed in the list.
Get a Porsche Car Insurance Quote
FOLLOW 911UK ON FACEBOOK
Daniel
2000 Porsche 996 GT3 Mk1
PostPosted: Thu Jun 19, 2008 10:52 pm    Post subject: Reply with quote
Great Post, nice gearknob and hand brake ! Thumb
*Current - GT3 996.1 Clubsport (Manthey K400)
EX VR993 - C4
EX 993 - C2
EX GT3 996.1
EX Cayman 3.4 S 987.1
EX Megane R26R #36.
EX Cayman R
AndrewM
PostPosted: Thu Jun 19, 2008 11:03 pm    Post subject: Reply with quote
Great work Stuart, I am very tempted. Even if I stay conservative and keep the console its very useful to have the removal tips.
NLW73
PostPosted: Sun Oct 11, 2015 7:48 am    Post subject: 996 GT3 mk2 centre console delete Reply with quote
folks
I have a comfort car with half cage and buckets etc.
I am over 6ft and would like to remove the lower centre console (with the storage bin and CD holders) as having driven an RS recently its far more roomy for the legs etc.
has anyone done this?
is it a big job?
can it be changed back when done?
it looks like you need some additional carpet and a blanking plate for the end of the console with the window switches.
many thanks, Nick
996 GT3 mk2 - Guards Red
996 C2 3.4 - Ocean Blue
NLW73
PostPosted: Sun Oct 11, 2015 8:14 am    Post subject: Reply with quote
Pelican Parts seem to have a kit in black.
Porsche Front Center Console Delete Kit,
looks like about £150 for it delivered to UK with current FX rates and seems fairly easy to do.
any input welcome Wink
Stuart
PostPosted: Sun Oct 11, 2015 9:38 am    Post subject: Reply with quote
One of best and easiest interior mods you can do. Totally reversable, all parts come in kit including carpet.
100% recommend this for extra leg room.
DIY here http://911uk.com/viewtopic.php?t=36881&highlight=console+delete
Pictures are loaded backwards, old forum problem, read from bottom up...
NLW73
PostPosted: Sun Oct 11, 2015 2:24 pm    Post subject: Reply with quote
thanks Stu
where is best place to get from? some folks are saying local OPC rather than the US.
Stuart
PostPosted: Sun Oct 11, 2015 3:30 pm    Post subject: Reply with quote
Local OPC will be cheapest.
Stuart
PostPosted: Sun Oct 11, 2015 7:19 pm    Post subject: Reply with quote
part number for black:
98655211302A10
see diagram below, part number 1 which should include parts 2 and 3. Also confirmed by below link.
https://www.ecstuning.com/Porsche-2002-911-996-Carrera-Coupe-H6_3.6L/Interior/Center_Console/ES1470071/
thebig25
PostPosted: Sun Oct 11, 2015 7:32 pm    Post subject: Reply with quote
Done 3 of these now, very easy - 20 mins ish to do.
Parts are about £130ish from OPC IIRC, but if you ask nicely i'm sure they'll do a bit off of that Thumb
2015 Cayenne Diesel
2000 996 C4
2003 996 Turbo- sold
2002 996 C2 - sold
2013 Cayman - sold
NLW73
PostPosted: Sun Oct 11, 2015 8:51 pm    Post subject: Reply with quote
thanks again stu and very helpful.
will pass those details onto my mate at OPC Portsmouth in parts Wink
NLW73
PostPosted: Mon Oct 12, 2015 12:59 pm    Post subject: Reply with quote
ordered part 1 and 5
£130 from the OPC. few days to come in.....
that's a bit of a saving over getting it from the US plus you have somewhere to return to in the UK.
EGTE
PostPosted: Tue Oct 13, 2015 3:57 pm    Post subject: Reply with quote
I feel robbed.....I just paid £131! Very Happy
Now I've pulled the pin on this mod, the current set-up is driving me nuts; it really does limit leg-room, doesn't it?
NLW73
PostPosted: Tue Oct 13, 2015 4:55 pm    Post subject: Reply with quote
yeah I agree. I was out in mine earlier and can't wait to get this sorted. let me know how you get on with it. will send you pm.
ELA
PostPosted: Tue Oct 13, 2015 6:22 pm    Post subject: Reply with quote
Any idea how much this item number 5 costs guys? (the little cover fwd edge of central console)
CLR996 1086kg bespoke design
NLW73
PostPosted: Wed Oct 14, 2015 7:51 pm    Post subject: Reply with quote
around £25 I think
Manic996t
PostPosted: Sun Oct 18, 2015 4:29 pm    Post subject: Reply with quote
can someone advise p/n for metropole blue please.
thanks in advance
