Puncture today!
Jamie_G
Portimao
13 Apr 2006
4,311
Went to get in the car this morning and thankfully I noticed a puncture.
Porsche assistance were great in coming out, taking the wheel off and identifying where the puncture was. They have put me on a spacesaver - big red thing and have taken my wheel to Surbiton Tyre & Wheel (nice and local). Later this afternoon they will have a new identical tyre on for me.
The tread on all the others looks like c.5mm - my question is.....
Should I be getting two new tyres on the rear instead of one or is that only a problem if you mix tyre type?
Yes!
Are they definitely getting a new one not repairing it? If so I would agree new is probably best way to go....
Jamie - somewhere in the handbook it will say something like - if the tyre depth on 2 tyres accross an axel differs between X.X % then new tyres of the same depth must be fitted.
Well it says that in the 993 handbook.........or i read it on t'internet...... :D
Then again Porsche assist should know? :?:
The technician only advised me to put one new tyre on which is what I have done.
So, is there a major problem with this?
ABS/PSM might, and I say might pick up on a differing rolling radius and cause them to act in an unusual way.
I remember having a few problems with my wife's 330Ci, when I drove it in a spirited way the DSC would kick in places where I'd never seen it happen before, sweeping left incline off a motorway the DSC light would be flickering constantly. I did some investigation and one of the rears was replaced at some point by the previous owner and there was a good few mill. difference left to right resulting in the problem. The BMW dealer replaced both tyres and problem was solved.
Jamie said:
...and have taken my wheel to Surbiton Tyre & Wheel (nice and local)...
Hi Jamie - I've used these guys several times for new tyres / puncture repairs etc. Always been happy with their work and the prices are pretty good.
tim
Tim, they did a good job indeed.
Damian, I drive the car pretty conservatively (noting i still have 5mm left after 9k miles) most of the time i.e. never get PSM going normally so would you recommend that I see how I go for a week or so? Wanted to avoid shelling out another £300 quid if possible - but not if it is really a problem.
Any more view on the topic?
I was told if there was 1.5 to 2mm difference you need to consider changing the other tyre also, in fact this is what I did when I got a puncture last year.
The manual for the C2S states the tread depth deviation "must" not exceed 30% on one axle. So 8mm depth on the new tyre x 30% = 2.4mm. Therefore the minimum depth of the other tyre on the same axle "must" not be less than 5.6mm.
Hope that helps. :thumb:
you could esnure you turn more often to the side of the old tyre, that way after a few thousand miles, the new tyre will have caught up... 8) 8)
Heavy duty roundabout session? :p
On the way to the 'Ring if on the wrong side :mrgreen:
I had a rear swapped about 3000 miles in due to a pot hole.
I replaced just one tyre with no long term issues.
garyw
I will go and buy a tyre depth guage today then and make a call on it.
Thanks for all your views.
124,591
1,441,860
49,021
Camarocane
