austinpowers
Well-known member
- Joined
- 23 May 2007
- Messages
- 162
Guys, can anyone recommend some brakepads for road use (mostly) for a 964RS
cheers
cheers
PolarExpress said:I would suspect either OEM or Pagid Blues would be a good bet if it's mostly road use (ie, with 2-3 trackdays a year)
Seagull said:OEM pads. The brakes on the car are so good, they don't need uprating. The only thing you might want to do is change the fluid to something like ATE Blue
911UK said:For road use OEM is fine, only if you venture onto track a few time do you need upgraded pads, but an inexpensive fluid upgrade works a treat
