davidstevenjames
Member
- Joined
- 20 Nov 2007
- Messages
- 8
gents,
I also need a set of rear calipers (radial mounted) to fit the above disc size (312 x 20mm).
Naturally the caliper can run bigger sizes but i dont want to waste too much of the possible contact area so limit is probably 320 x 28mm or thereabouts.
anyone got anything?
cheers
david
cheers
david
