Newbie Guide-911uk various porsche shorthand abbreviations
c.afsar
8 Jul 2007
724
Hi All,
My very first post - so please dont bite!
I have been browsing this forum for the good part of 6 weeks now and figured this may be a useful topic for newbies to this forum and porsche, with the similar likes of me!
I am wondering if you guys could add some of the terms used when discussing the 911 and abbreviations used on this forum....
some of them (and i hope ive worked them out rights are as follows)...
OPC- Offical Porsche Center
TT - Triptonic
PSE - Porsche Sport Exhaust
PCM - Porsche Communication Management
Feel free to Add...
Cheers,
Afsar.
c.afsar said:
Hi All,
TT - Triptonic
Feel free to Add...
Cheers,
Afsar.
TT isn't Tiptronic, basically some people call the Turbo a TT, as in Twin Turbo, personally I call it a Turbo, after all that's what it's got written on it's bum :)
PASM - Porsche Active Suspension Management
PSM - Porsche Stability Management
LSD - Limited Slip Differential
ABD = Automatic Brake Differential
TC = Traction Control
RS = Renn Sport
and I'll leave PU for someone else to answer is no less than 1000 words !
Sundeep said:
RS = Renn Sport
is that it ?
easy.......polyurethane
we're all forgetting the most essential abrv.........especially when looking to buy one
PPI-pre-purchase inspection
and one for the water-cooled boys- :twisted:
RMS-rear main seal
DME = Digital Motor Electronics
Can anyone shed some light on what RMS please?
heard alot of bad news about it... but google not giving me any pointers ;)
Rear Main Seal - It's the seal through which the crank exits the crankcase before the flywheel and then the clutch. It is prone to failure on the watercooled engines because of the movement afforded in the crank due to the distance between the seal and the last crank journal. It is not so prevalent in the Turbo and GT3 engines because the bottom end of these is based on an older and more expensive design/manufacturing solution.
See also, Intermediate shaft seal which is the seal on the shaft which drives the ancillary components, rather than put all of the load on the crank.
PCGB- Porsche Cars Great Britain, or Porsche Club Great Britain.
PCCB- Porsce Ceramic Composite Brake
PCM- Porsche Communication Module (1 or 2, 2 being a newer version. v1 no longer supported by Porsche for nav discs)
MAF (Dunno what it stands for, but its an airflow meter. When it conks out, your 996 runs funny)
OBC - On Board Computer
OEM - Original Equipment Manufacturer
HID - High Intensity Discharge
Struggling with all the Porsche acronyms & abbreviations
A silly question to ask perhaps but here goes anyway... As a new comer to this splendid site I must admit that I've really struggle with some the acronyms & abbreviations you old heads are constantly using (I have to trawl through some old posts to try and find out what some of them actualy stand for) :? !
PSM, PCM, OPC, PU, RMS, ISB, HID, VIL, MY, TSB, PET etc, etc to name but a few.
Is it possible to have some sort of guide or link put together for us new comers detailing all of them, as it can be quite annoying following a thread only to be stumped when someone uses one of these? :)
I'll have a stab at these for you
PSM - Porsche Stability Management System
PCM - Porsce Communications Management (Satnav)
OPC - Official Porsche Centre (Garage)
PU - PolyUrethane (Bumber)
RMS - Rear Main Seal (seal between gearbox and engine)
ISB - Intermediate Shaft Bearing
HID - High Intensity Discharge (Lights similar to xenon)
VIL - ?
MY - Model year (year car was built)
TSB - Trustees Savings Bank ;-)
PET - (its the system you order parts and get information off) no idea what the abbreviation is though
Rich H will be along soon to mark my work ;-)
Thanks lads.. I have to say that smj996c's reply on TSB had me in stitches! :floor:
Porsche Acronyms
These are a few I had listed:
ABD - Automatic Brake Differential
ABS - Anti - lock Brake System
AOS - Air/Oil Separator
CAN - Controller Area Network
CDR - Compact Disk Radio
DME - Digitale Motor Elektronik (Engine Control Unit)
DSP - Digital Sound Processing
HID - High Intensity Discharge (Xenon - type lights)
IMS - Intermediate Shaft/Seal
MAF - Mass Air Flow (sensor)
MOST - Media Oriented Systems Transport (Fibre optic comms loop).
MY - Model Year
OBD - On Board Diagnosis
PCM - Porsche Communications Management (Satnav etc)
PET - Porsche Elektronik Teile (The Porsche Parts Program)
PIWIS - Porsche Integrated Workshop Information System
POSIP - Porsche Side Impact Protection System
PST 2 - Porsche System Tester 2
PU - PolyUrethane (Front or rear bumper material)
RMS - Rear Main (oil) Seal
RoW - Rest of the World
TC - Traction Control
TSB - Technical Service Bulletin
VIL - Vehicle Identification Label
Edit: Originally posted on the 996 forum in response to The Gogg.
As well as the Porsche acronyms the other thing that took me a while to pick up was the "forum-ese". Here's some I think I've figured out, but you can tell me I'm wrong..
OP - Original poster (ie originator of thread)
AFAIK - As far as I know
IIRC - If I remember correctly
H
ETA:
ETA - Edited to add
IMHO - In my humble (!) opinion
As it turns out harry your post was the most useful to me Lol ...only joking lads ,great idea. :thumb:
2WD
ABD
ABS
ACS
AHK
AHKS
AIR
ASR
ATF
AUX
AWD
AWS
BHP
CAI
CAN
CDC
CDR
CEL
CL
CPO
CVN
DDD
DFI
DFRDTE
DME
DOHC
DQSDTE
DSP
DTC
ECM
ECT
ECTS
ECU
EDC
EGAS
EGR
EGT
EOBD
EU2
EU3
EU4
EZK
FR
FR2
FRA
FRA2
FTEA
GHV
GPS
GW
H02S
HBA
HFM
HVAC
IACV
IC
IMS
IV
KESSY
LDR
LEV
LH
LHD
LSA
LSD
LWR
MAF
MAP
ME
MIL
ML
MOST
MSR
MV
MY
NOS
OBC
OBD
OBD II
OEM
OPC
PAS
PASM
PCA
PCCB
PCCC
PCGB
PCM
PCNA
Pcode
PD
PDAS
PDCC
PDI
PDK
PET
PHC
PIWIS
POSIP
PSD
PSE
PSM
PST2
PTM
PTS
PTV
QADP
QSOL
RDK
RF
RHD
RMS
ROW
RPM
RTS
SAE
SBS
SC
SDARS
SES
SRS
SSK
TB
TC
TCC
TGSS
TIP
TL
TOP
TPC
TPM
TPS
TR
TRA
TRA2
TSB
TWC
UAI
USAC
USAC2
USBC
USBC2
VIL
VIN
VTG
VTS
WOT
124,591
1,441,863
49,021
Camarocane
