997 : 2004- 91
996 : 1997-2005 43
Boxster : 1997- 14
Cayman : 2005- 15
Cayenne : 2003- 8
Macan : 2014- 0
Boxsey
Watkins Glen
1990 Porsche 964 Carrera 2
PostPosted: Mon Mar 23, 2009 10:20 pm    Post subject: Reply with quote
ldt wrote:
Interesting thanks Boxsey.
On the 993 calipers there are two nipples per caliper. I take it both need to be bled?
This being the case does it matter which one 1st? Or aslong as u start with the furthest caliper away from the reservoir, makes no difference?
Yes even on our older model we have two on each too! I figure that the outside nipple is furthest away from the brake line that feeds the caliper so always do that one first.
I would also recommend you use a proper 11 mm brake spanner or 6 sided spanner to guard against rounding off stubbon bleed nipples.
Steve
Racing Yellow Cayman GT4
History of my now gone 964
ldt
Paul Ricard
1995 Porsche 993 Carrera 2
PostPosted: Tue Mar 24, 2009 2:12 pm    Post subject: Reply with quote
Will do thanks Steve, other than that is the ABS not something that needs
to be worried about?
Think I will treat the car to some of those fast road pads whilst Im at it Thumb
Better 2 burn out than 2 fade way
Boxsey
Watkins Glen
PostPosted: Tue Mar 24, 2009 2:44 pm    Post subject: Reply with quote
On C2s there's nothing else to worry about. Some bleed the clutch slave aswell but this is a PIA on a 964 (don't know about a 993). However most of us only bleed the slave if the gear shift starts getting difficult. I believe there's something else to do when bleeding brakes on a C4 but luckily I don't have to worry about what that is Grin .
Steve
Goto page Previous  1, 2, 3
Page 3 of 3
