Porsche 911UK Forum
996 Front Speaker upgrade
Status
Not open for further replies.
Carrera4S
Banned
16 Oct 2006
3,006
Ok, I've completed Phase 1 of the speaker upgrade......
More floor pics, a sort of before and after.....
I carefully cut a hole in the blanked off missing tweeter area.....
The MB Quarts have a steel ring that really helps with the mounting, a couple of rings of normal Dynamat (the browny stuff) provides an excellent sealed aperture when this ring is placed inside the OEM aperture.
As you can see these MB rings have had their speaker mounting edges 'removed', this will allow me to bend the tabs around the OEM aperture securing them in place.
The speakers were sealed using Dynamat Extreme, help dampen the whole affair:
The tweeter and midbass units were then epoxied to the OEM cradle, epoxy is great, if you buy the 1 hour setting version, the 1 min 'crap' is awful stuff! Using epoxy helps when returning the car to standard as it 'cracks' off when assisted with a screwdriver and Stanley knife.
So off to the car......
Remove the headunit!!!! Thanks Porsche, mine's away on hols with them at the moment.
Remove the instrument binnacle, hidden screws, T20 Torx screwdriver at the ready!
On previous installs I've always used the existing wiring because I'm a lazy barsteward, this time I decided to feed additional cables, one for the tweeter and one for the midbass. Removing the binnacle helps you feed the cables into position - you can try and do it without removing it but it's a right PITA, the passenger side is easy, you can reach up from inside the centre console to the speaker whilst pushing the cables through.
I took picture before the second set of cables were fed through but I'm sure you can get the idea!
I also removed the aircon control, just two screws it helps if you have big hands.
Now to mount the crossovers.....
They looks good on the dash don't you think? We'll come back to those later.....
This is a standard ISO to ISO extension, we are only going to use the speaker cables side,
What you need to do here is attach 4 longer (18") cables to the end of the ISO that connects to the stereo, not the other! Solder, butt connectors etc will do the job perfectly. Then you want to connect these cables and the ones going through the dash to the crossovers.....
I mounted the crossovers under the stereo, surprisingly there's enough room there for an entire family of refugees!
The 4 wires exiting from the 'hole' are those attached to the ISO extension.
At this point you need to make sure the cables are all tidied away, routed the holes in the dash so you reconnect the stereo, remember to connect the black 8-pin connector to the ISO extension and the other end of this to the stereo the same applies to the brown plug!
On the cables sprouting like weeds from the speaker holes you will need to attach spade/bullet connectors to help attach them to the speaker. With mine, I used bullets to attach the tweeters and spades to attach to the midbass.
Once done insert back in the holes and the job's a good un!
Words to the wise.....
1. When mounting the speakers to the OEM cradles, try and get the cable mountings in the centre. If any cables are on the outside you struggle to re-insert them in the hole.
2. Take careful note of the - and + on the speakers, it won't blow up but you'll get phasing problems if you mix them up.
3. When removing the binnacle, lay down a towel over the dash to protect the dash.
4. To remove the dash speakers use a Torx allen key or tiniest ratchet (I found one in Maplin) and Torx screwdriver bit.
5. Put two washers here:
Without these you'll struggle to get the newly fabricated unit mounted properly.
Migration info. Legacy thread was 138290
great work there fella
Do you also have rear speakers in yours ?
Yep, just fitted the bass unit (as above), didn't bother with the crossover or the tweeter.
Status
124,358
1,439,469
48,716
993gtnut
