This thread has prob been done 100 times, apologies for that - but I wanted to ask the experienced owners.... what grade of Petrol you use. My manual says run on 98, but the dealer (non-OPC) but experienced seller says "just stick unleaded 95 in it - you won't notice the difference" I know the ECU will adapt using anti-knock technology, but whats the views?? If I run on V-Power (for example) will I notice sharper response or it just not noticeable?
Also, I was reading about the ECU needing to "learn" if a mod is made to induction or exhaust and perhaps using different fuel?? Meaning that the ECU takes time to adapt over some miles before it optimises settings for the particular adjustments? Can anyone verify this or is it BS!!!
Thanks....
Migration info. Legacy thread was 126677
Thanks....
