3.3 turbo 2 1992 engine removal
stu.p
27 Sep 2006
5
hiover the festive period my car developed the dreaded "flut flut flut" noise on tick over from especially underneath the car and when switching the engine off sometimes could be heard just before the engine came to a halt!!..i had been running the car now at 1 bar boost(peaking slightly above then resting at 1 bar) and with a cat bypass pipe fitted..after checking the usual,when i removed the lower cam cover i found 2-off in total head bolts with part of the broken stud in them which have snapped and fell into the cover,,i will obviously have to now remove the engine to start with to start a rebuild,,i have always done all my own maintenance on my cars but was looking for to start with the procedures for removing the engine on this model,,car is a 1992 3.3 turbo with 94,000 miles on the clock and was bloody pulling like a train before and even now!!!advice from yous more than welcome,,cheers!!
Migration info. Legacy thread was 105467
taking engine out of 964 turbo is a fair bit of work as the engine/gearbox both come out together from the bottom. It is done with large trolley jack and special plate to rest engine onto. That said all fuel lines and most of the wiring is at the top, and is of plug in type connectors. Main enine oil pipes can sieze and may need heat to remove without damage. See what you can locate in the way of jacks etc and if you are still up for it I will give a bit more detailed instrutions.
Migration info. Legacy thread was 105642
yeah im still up for it!!jacked up the car far enough and it is now sitting on ramps at the front and sitting up well high on the rear on axle stands,,would appreciate as much info as poss,,or any wshop manauls,books etc to get a hold of specific to my car!!!
Migration info. Legacy thread was 105751
124,587
1,441,769
49,011
Mchass
