Starting to plan a new subwoofer. I did one for my other car , was really happy with the result. The report can be seen elsewhere in this forum.
Anyway , I have the stock CDR23 , with no sub. No Bose. It sounds OK. But I am sure adding a sub , would make it MUCH better. After some investigating , I think... the left side storage box , in the trunk , should easily be able to put one 8" unit ther.Maybe even 10" one.
Already fabricating a stronger panel to replace the existing one. I will mount the element on that new stronger piece , make sealed box behind that piece of board , and mount the whole thing there. Replacing the existing panel.The new panel will be made of MDF , trying to fabricate a sealed box behind it from glassfiber....
The questions : where can I get the signal to run the Sub Amp ??? It has some fancy optic / fiber / BUS system..... I have been told. AAAARGH !!! The Sub Amp will be mounted at the rear cargo area , under the cover. There is plenty of room. I was told there is an amp , on the right side of the trunk. Can I "steal" the signal from that amp ? If , then how ? From the outgoing speaker lines?
Any tips & ideas or tricks , or your own improvements greatly appreciated !
e k i
Migration info. Legacy thread was 104768
e k i
