97 Boxster annoying rattle
Wogster8
7 Aug 2006
1
I have a mint 97 boxster, but there is an annoying light metalic noise coming from the rear right wheel, sounded like spring tension clip on the brake caliper but is not that nor the light metalic protection shield behind the brake disc ! I was wondering could it be the hand brake cable ? anyone had a similar problem and if so how do I go about fixing it ? it happens with vertical movement and only occassionally not over every bump and when you expect it to rattle it wont just happens on minor fluctuations in the road surface !! Annoying !! help much appreciated
Migration info. Legacy thread was 68711
Nothing worse than a rattle like that. I had an XKR once that could have served as the 'annoying noise' module case study for the City and Guilds motor maintenance course.
A similar noise was traced to the handbrake linkage- you can tell as the noise goes away when you gently pull the handbrake to apply a bit of tension.
Other than that, maybe a bushing?
Migration info. Legacy thread was 68716
124,608
1,442,034
49,038
DD77
