Going to see this car tomorrow
http://www.pistonheads.com/sales/74344.htm
seems like a nice guy, he emailed me pictures of the wheels, which need refurbing (below) and the recent invoices as a pdf
As he says in the ad it's had
Brakes done, wishbones and frnt Pzeros @ 154k miles in feb 04 @ £2k
DME and ignition relay done @156k miles in Apr 04 @ £200
RS clutch and flywheel fitted along with all manner of different oil pipes (how many could you possibly need), and rear pzeros @159k miles in Jan 05 @£2.7K
Central locking fixed @156k miles in May 04 @£330
Top end stripped down and de coked with gasket set, piston rings rocker shat oil seal kit, lower end gasket set, valve clearence adjusters and ignition lesd set @160k miles in Mar 05 @ £3K
2 Fuel injectors replaced and 4 overhauled @161k miles in may 05 @ £1k
All done at porscheworx in hampstead
Only other comment is small patch of corrosion around front windscreen which needs attention.
All comments greatfully recieved
/images/migration/UploadedForumImages/wheel(3).JPG
Migration info. Legacy thread was 66527
