Does the 04 GT3 lower lip scrape?
Dr Raj Kohli
19 May 2006
7
Hi all
Having a '04 GT3 front bumper with lip spoiler fitted next week. Am a little concerned that the lower lip may scrape against speed humps. Is that the case?
Would appreciate your advice
Migration info. Legacy thread was 60063
Depends on the speed hump :)
A standard 996 rides higher than a GT3, but even with the GT3 there are only a couple of places I've found the front scrapes. In both cases it actually scraped on the road coming down from the hump. Don't worry about it as it shouldn't be an issue.
Migration info. Legacy thread was 60064
also is the lip plastic or rubber ? makes a difference
Migration info. Legacy thread was 60066
If it's the lower lip then it's a strip of black rubbery stuff, but not sure it's rubber
Migration info. Legacy thread was 60072
I had to replace the front splitter, (Robs black rubbery thing)
they are designed to come off and scrape because it saves the bottom of the bumper. However i dont usually get problems with mine and the CS sits 10mm lower.
If you ever need to replace, use the PMS ( Porsche Motor Sport) item its a lot cheaper, and is supposed to work better!! jurys out on looks tho..
...rob
Migration info. Legacy thread was 60084
welcome aboard Dr Raj :)
Migration info. Legacy thread was 60095
124,608
1,442,037
49,038
DD77
