Matthew Clunk
- Joined
- 3 Oct 2005
- Messages
- 81
Hi - I've fitted a Porsche Becker CDR-22 to my 993 and essentially it plugged straight in. There are 3 spare outlets on the back of the unit:
- lines-out
- external cd/md control
- telephone module control.
I would like to use the output for cd/md control on a compatible Sony 6MD changer I have acquired but it looks like I will need a custom cable. Can anyone supply infor on where I can get a suitable Becker to Sony CD/MD control cable or a suitable plug (as I've got a spare Sony cable I could adapt if I knew the pin-outs).
Just to confuse matters my 993 has a spare loom/plug hard-wired which is either the CD/MD control or Telephone control (as the plug is the same for both of these). Can anyone tell me which it is likely to be on a '97 993 and where the other end of the loom is likely to be?
On another note the display on my Becker unit is very dim even with the instruments turned up to full brightness. - does anyone know if these units can be sent off for repair.
M
Migration info. Legacy thread was 47090
- lines-out
M
