991 : 2011- 20
997 : 2004- 78
Boxster : 1997- 25
Ray
PostPosted: Fri Jul 15, 2005 7:23 am    Post subject: Reply with quote
Morning all
I,ve got that awful creaking windscreen problem on my 993.
I have spoken to one of the specialists regarding the PTFE Tape cure, but they say this does not always work and that the most reliable methord is to reseal the windrcreen after removing it.
Anyone have any experience of this procedure and any idea on cost?
They also suggested as a short term fix to spray WD40 or similar between the windscreen cover strip and the window, apparantly this stops the noise until the spray dries out, again anyone tried this?
Migration info. Legacy thread was 31375
Westyman
PostPosted: Fri Jul 15, 2005 9:30 am    Post subject: Reply with quote
Morning Ray,
I've got a 993 Targa which had a creaky targa roof. I bought a small bottle of Glycerine from Tesco's for approx 1 and used it to lubricate the rubber components of the roof.
I don't have any more creaking or squeaking and it appears to make the rubber more supple.
I'd try applying the Glycerine under the windscreen seal using a pipette. The glycerine will last for ages.
John
96 993 Targa
Migration info. Legacy thread was 31383
JonH
PostPosted: Fri Jul 15, 2005 9:39 am    Post subject: Reply with quote
My car had a creaky windscreen and already had the teflon tape fitted, solution was to apply vaseline between the windscreen rubber seal and the bodywork (not screen) = no creaking.
Migration info. Legacy thread was 31384
Evil Jack
PostPosted: Fri Jul 15, 2005 10:01 am    Post subject: Reply with quote
I've just bought some 'silicone spray' (safe for rubber-I wouldn't use WD40!)and sprayed it between the bodywork and the seal. Not only has it NOT WORKED, but it's left oily streaks across the roof and doors after driving the car. Rolling Eyes
Migration info. Legacy thread was 31385
Ray
Thanks fellas
I'll give your ideas a try
Migration info. Legacy thread was 31386
Ray
PostPosted: Mon Jul 25, 2005 7:06 am    Post subject: Reply with quote
Jon H
Tried the vaseline last week, it seems to have done the trick, Im getting a few creaks from the rear of the car so I will try iy on the rear screen rubbers as well.
Migration info. Legacy thread was 31740
