Oil Pressure Gauge
Gary G
31 May 2005
1
I just bought a 1988 3.2 at the weekend and it's my first Porsche. On the second day of ownership the oil pressure gauge has started to play up by first twitching between min and max very quickly and then staying at the top of the scale the entire time that the engine is running. Is there any way of testing the sender unit so that I can determine whether it is this that is faulty or the gauge.
Migration info. Legacy thread was 29348
I would say this is normal - to test the sender - start the car, go for a longish drive (30 mins) and then let it sit idling for 3 mins - the needle should stay in one place.
Do a search - this has been covered before.
Good luck with your car.
Migration info. Legacy thread was 29359
good car the 3.2 carrera if it was not the gauge it would be very smoky or low on power or even smell oily or go bang so its the gauge
Migration info. Legacy thread was 29360
i disagree - with my 3.2 the pressure gauge would at high speed running drop down to Zero.
Best thing is to get is checked by a garage.
Migration info. Legacy thread was 29361
Seems to be a little confusion in some of the replies I think maybe Warren M is thinking of oil level gauge instead of the pressure gauge.
If your oil pressure gauge is reading max. with ignition on, engine not running, it may be a break or bad connection form the oil pressure sender unit.
Try a serch on
http://forums.pelicanparts.com/forumdisplay.php?s=&forumid=8
for this topic, a wealth of tech info here.
Migration info. Legacy thread was 29365
im just saying that with my car, on a very high speed run, the Pressure needle used to drop to zero. Then slowing down it used to move around the scale quite a bit and would only remain static once the car was idling.
If you rev the engine the pressure needle should move up the scale, upon lowering the revs it should move down the scale.
Migration info. Legacy thread was 29367
A friend of mine bought a 3.2 carrera six months ago that developed a similar problem with the needle behaving erraticaly at all times whether at idle or driving. Car drove fine and after taking it to a specialists (Northway) faulty sender unit was diagnosed. Could also be a bad connection on the gauge - try removing it and cleaning connection.
Migration info. Legacy thread was 29370
sure you are not on about the oil level gauge the oil pressure gauge is a different one if you have no oil pressure its time for a big bill
the oil level gauge is very erracit with the needle going up and down but the oil pressure gauge rarly moves
Migration info. Legacy thread was 29374
im fairly sure, but then again maybe im not - my 993 is hopefully being sold tonight, so maybe im just delierious.
Migration info. Legacy thread was 29375
you buying a ferrari then ha ha ha
Migration info. Legacy thread was 29376
yeah..............................not. If/ when i do buy another 911 it will be a 3.2 or 930.
BTW - i was behind a fiat Coupe last night on the way home and he had stuck a Prancing donkey on the back - do u have an insight into why? :?
Migration info. Legacy thread was 29377
yes to annoy porsche drivers looks like it worked
get a 3.2 supersport with G50 gearbox its the best porsche made and cheap to run
Migration info. Legacy thread was 29379
it didnt annoy me - it just made me feel sad. for him.
Hmm - im not a fan of the supersport, but yes a g50 box is on the list.
Migration info. Legacy thread was 29380
Supersports rule 8)
Migration info. Legacy thread was 29381
Quote: Originally posted by supersport on 01 June 2005
Supersports rule 8)
Yes of course they do FF - :wink:
Migration info. Legacy thread was 29384
124,596
1,441,953
49,028
Baltic928GT
