993 Alloys (will they fit?)
Daniel
2 Feb 2005
12,181
depends on the ET offset
is yours a narrow body car ?
Migration info. Legacy thread was 28929
Dan, for your narrow body 993 you will need ET52 for the fronts and ET65 for the rears. 996 narrow body offsets for 8" fronts were 50mm and 10" rears were 65mm. But both 50 and 52 will work for the fronts on a 993
Boxster used the same fronts but ET47 rears for 10" wides. You can use spacers on a 911 wheel to fit a Boxster (but not the other way around).
These ones would work :wink:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&category=10408&item=4551302168&rd=1
Migration info. Legacy thread was 28930
Thanks,
She is a narrow body vehicle, and I just would like to change to look a bit different
17" or 18" (wouls I need to have a wheel allignment, changing to bigger wheels?)
Dan
Migration info. Legacy thread was 28939
putting on 18's is as simple as putting them on !
reduced tyre profile allows for larger wheel
Migration info. Legacy thread was 28940
Cheers Sundeep, do you know what size to go down to ?
Dan
Migration info. Legacy thread was 28942
fronts from 17" set of 205/15/17 they become 225/40/18 for the 18's
on the rears from the 17" set of 255/40/17 they become 265/35/18 on 18's
for the Narrow body 993 (difference only on the rear) as Wide Body can take 285/30/18's !
Migration info. Legacy thread was 28943
Thank Sundeep.
What would we all do without you ?
Dan
:wink:
Migration info. Legacy thread was 28951
Hi Am going to look at a set of 993 Turbo alloys,
there have the right tyre size's and ET numbers front and rear,
But...
Cos there from a turbo, will they be ok for my narrow body 993 ?
Dan :?
Migration info. Legacy thread was 29033
If they are taken off a Turbo, the rears will have different ET's (40) from what you need (65) for your narrow body. If the ET's are correct for a narrow body then they aren't orignally off a Turbo!
Those ET's are for 10" Rear's by the way.
Migration info. Legacy thread was 29039
I assume you mean 'Turbo style' wheels Dan, i.e. with the twisted spokes? You see plenty of narrow body cars with them on so there must be a set which fit fine!
Migration info. Legacy thread was 29050
I have been told there off a Turbo !!
But the ET is-
ET52 front + ET 65 Rear !!
So I am thinking there fit ?
Dan
Migration info. Legacy thread was 29053
no matter what car they came off.. although a rear wide body Turbo iirc has an ETin the 40's....
as long as the ET at the rear is 65 it will fit...
Migration info. Legacy thread was 29055
cheers sundeep.
Dan
8)
Migration info. Legacy thread was 29074
Been offered a set of 18" turbo wheels..
BUT..
The front ET is ET50 will these be ok ?
Dan
Migration info. Legacy thread was 29349
124,608
1,442,035
49,038
DD77
