Headlight not working....help!
Robertb
Yas Marina
1 Sep 2003
8,406
I changed the headlamp bulbs in my 993 for the Osram Silverstars yesterday. Since then, the nearside headlight does not work, on neither full nor dipped beam.
I have checked fuses and bulbs (only changed dipped bulbs), all OK, and have tried re-installing the headlight pod a number of times. But no joy.
Any ideas folks?
Robert.
Migration info. Legacy thread was 25054
as you've checked everything already... unsure ... recheck ?
Migration info. Legacy thread was 25060
Robert,
Had a similar problem on mine. If you look at the small clip which holds the bulb in place, is it pushing the bulb firmly against the metal bulb holder? Mine wasn't since the metal on the holder which the clips sits in (you still with me!) had started split, therefore the tension in the clip was no longer there.
After adding some additional bends in the clip, I was able to ensure that the bulb was firmly held in place.
The reason your not getting dipped or full beams is that the negative connects to bulb through the metal holder and serves both lamp functions.
Hope this helps
Paul
Migration info. Legacy thread was 25070
Again, 911uk yields the answer and saves man trip to specialist; checked and rechecked, and tweaked and refitted bulb clip wire bit thingy. Light now works!
Thanks Paul, Sundeep.
Regards
Robert.
Migration info. Legacy thread was 25075
great tip there paul !
the power of a mere clip, tested it out today.. and yes it works or rather doesn't work, which means it works ! or something like that !
Migration info. Legacy thread was 25111
124,589
1,441,825
49,017
mapp
