flat battery
Peter Bird
25 Nov 2003
248
I hav'nt used my car for a couple of weeks, needless to say the battery is now flagging a liitle (dead!)
If I want to charge it up with a normal battery charger do I need to disconnect it first or can I charge it connected.
Migration info. Legacy thread was 15521
Should be ok to leave it connected - but then again will not hurt to lift the battery termials off to be on the safe side - still leaving it in the car.
Migration info. Legacy thread was 15523
Thanks Johnboy
Only problem with disconnecting the battery is I have to re-enter the pin number to the stereo and I don't think I have it. My main concern was on the older cars I beleive it sometimes damaged the diodes in the alternator. With all the modern electrical gizmos on the 993 I did'nt want to fry anything.
Migration info. Legacy thread was 15524
You do not need to disconnect the battery but you should leave the bonnet open and have the garage well ventilated whilst it is charging. Remember, the 'boot' light will normally stay on while the boot lid is open so you need to hold down the switch by putting a short piece of wood between the switch and the car if you want to reduce the charging time as much as possible.
There is a gadget called an 'Optimate' about £40 which can be left connected over periods when the car is not being used. It reads the charge level in the battery every 30 mins and 'tops it up' as necessary. Better than an ordinary charger!
Migration info. Legacy thread was 15529
Thanks Bill, battery being charged now. I will make enquiries about the optimate.
Migration info. Legacy thread was 15544
124,531
1,441,201
48,939
Autocraft1
