Sticky Goo
Percy1
5 Feb 2004
14
Hi
Just traded by 1995 993 c2 for 1996 C4 with all the bells and whistles and very happy. However, the dealer has removed the original supplier lables (HR Owen) from the front and rear screens, this has left some rather unsightly sticky marks that don't seem to want to come off. So far I have only tried meths but any advice would be appreciated.
Percy
Migration info. Legacy thread was 14289
Lighter fluid will work.
Migration info. Legacy thread was 14290
Thanks Bosch, will give it a go this evening. Will lighter fluid also work for the glue left on the wheels from previous balancing weights?
Percy
Migration info. Legacy thread was 14317
For the wheels I've found that Autoglym Tar removerer is perfect for this job. Their glass cleaner is also good for polishing all glass after u've removed the sticky goo.
Migration info. Legacy thread was 14318
Jonathan
Do you think the tar remover will work on the glass as well, not had too much luck with the lighter fluid, was going to try something a bit stronger like nail varnish remover but that might be too harsh. Anyway, will give it go this weekend and see what happens.
Percy
Migration info. Legacy thread was 14388
try a stanley blade at a narrow angle, thisshould lift of the hardened top layer and leave a softer layer that the lighter fluid should remove. Failing the ligter fluid try brake cleaner.
Migration info. Legacy thread was 14402
124,603
1,442,001
49,036
barrywhite
