colintinto
- Joined
- 14 May 2003
- Messages
- 64
Hi All,
Last couple of times I've had the car out it has developed an annoying buzz coming from the rear somewhere. You only hear it as certain revs, or sometimes with certain bass notes at reasonable volume on the stereo.
I've been in the back and taps a few bits, especially speaker grills etc, but everything seems solid. But then I hit the top of the rear glass, and can hear a bit of a rattle.
It looks lile the spoiler/third brake light holder is slightly loose, and might be the culprit. Can someone with a 993 (an no noise!) give their brake light holder a bit of a tap and see if it sounds a bit loose/rattly?
Any ideas how the spoiler bit is held on? No obvious signs. I had a look in through the zip inside, but there are extra panels to remove to see anything and I've not done that yet.
Colin
Migration info. Legacy thread was 11052
Colin
