997 : 2004- 87
996 : 1997-2005 41
993 : 1993-1998 6
Boxster : 1997- 15
Macan : 2014- 0
Mike Horsburgh
PostPosted: Wed Aug 13, 2003 10:34 am    Post subject: Reply with quote
Hi All
I think I'm about to buy a '77 Carrera 3.0
Do they have the dodgy cam tensioners and should I get them changed (how often??) or are they the uprated ones which don't fail as often - is there still a service recommendation on them?
Thanks...quick reply would be great, as I have to move quickly to buy the car.
Migration info. Legacy thread was 7152
Jamie Summers
1992 Porsche 964 RS
PostPosted: Wed Aug 13, 2003 11:40 am    Post subject: Reply with quote
Mike,
Pretty sure the 3.0s have the old type - but the mod to the oil fed tensioners is a very common upgrade which may have already been done and if not it is a relatively cheap (in Porsche terms !) mod.
Either way with an older car like this it is all the more important to have a proper pre-purchase inspection done by an expert before you even think of handing over any money - you may save yourself a lot of time / money / anguish in the long run.
Migration info. Legacy thread was 7159
'06 Autofarm Cayman RS Development Car
‘99 996 C2
Ex '92 964 RS
Ex '93 968 CS
Ex '90 Clio Mk1 Cup Racer
Ex '90 964 C2
Ex '89 Carrera 3.2
Mike Horsburgh
PostPosted: Wed Aug 13, 2003 12:24 pm    Post subject: Reply with quote
Jamie
Thanks for the info...
Intend to get Autofarm to look at it before buy...but it's a VERY original 4 owner with 100K...
I've looked at 4 Carrera 3.0's and it's the best so far, by a good margin! Top dollar price, but worth it.
Thanks again...do you know any good specialists in Berks/Bucks/Oxon area?
Migration info. Legacy thread was 7163
Jamie Summers
1992 Porsche 964 RS
PostPosted: Wed Aug 13, 2003 1:29 pm    Post subject: Reply with quote
Other than Autofarm can't think of any off the top of my head. They're probably no the cheapest but they do come highly recommended. Also I suppose JZ Machtech is a possible - a quick blast round the M25 to Kings Langley ?
Migration info. Legacy thread was 7173
‘99 996 C2
Ex '92 964 RS
Ex '93 968 CS
Ex '90 964 C2
Ex '89 Carrera 3.2
CT993
PostPosted: Wed Aug 13, 2003 2:13 pm    Post subject: Reply with quote
Previous poster wrote:
From personal ownership experience I'd advise against it if you can and go for a 3.2 with the G50 gearbox.
Migration info. Legacy thread was 7186
James Ball
PostPosted: Fri Aug 29, 2003 2:12 am    Post subject: Reply with quote
I too have been looking for a Carrera 3.0 so would recommend them. Generally a few grand cheaper than a 3.2 (about 5 grand cheaper than any 3.2 with a G50 gearbox). Also they are that bit more different than an SC. Finally, if you ever do have to take the engine apart a set of new pistons and a cam re-grind can get you 250 bhp as they run a pretty low compression which can be safely increased (to the level later SCs used).
This is probably too late for you but I thought I'd reply anyway (I've been away for a while I'm afraid).
For specialists have a look under the 'Recommended Websites' forum (or something like than). THere is a short list there.
Cheers, James
Migration info. Legacy thread was 7611
____________
'89 964 C2
Mike Horsburgh
PostPosted: Fri Aug 29, 2003 9:54 am    Post subject: Reply with quote
Bought one...it'll be on the register stand at the Porsche Club Do on Sat at Eynsham Hall - had to look at lots before I found a good original one. Paid top dollar but that won't matter in 5 years when the value has gone up again.
In the event that it does need an engine rebuild (not too soon I hope) then I'll certainly look into uprating the power, although I'm finding it quick enough at the minute. The only rear drive cars I've owned before were Alfas, which are slightly more conventional in terms of weight distribution, so 200 HP and the arse end trying to overtake under heavy braking is quite enough at the minute Very Happy
Looking through the history file there's a receipt for tensioners with a part number, and the next line says Kit. I think this might be an oil fed tensioner upgrade....is there a way of telling from outside, or do you have to strip and inspect?
Anyone know which type of tensioner is part number:
930 105 911 00 - Tensioner - 114 in 1990
930 105 912 01 - Kit - 124
It's a main dealer receipt, so they're proper porsche part numbers
Also on the invoice are an oil filter and gasket, which ties in as you lose all the oil when you change the tensioners (courtesy of a bit of friendly advice from JZ Machtech)
Mike
Migration info. Legacy thread was 7618
noony
Watkins Glen
PostPosted: Fri Aug 29, 2003 10:59 am    Post subject: Reply with quote
The second ''kit'' is a 912 part number...its funny to see how old parts are used in newer cars...eg the 964 engine block was used in the 996 GT1. Congrats on your purchase.
James, you're back! Phil has been run off his feet.
Migration info. Legacy thread was 7622
Mike Horsburgh
PostPosted: Fri Aug 29, 2003 11:11 am    Post subject: Reply with quote
So is the tensioner the oil fed one then?
Migration info. Legacy thread was 7625
bones
PostPosted: Fri Aug 29, 2003 4:55 pm    Post subject: Reply with quote
If you have the later tensioners you can spot fairly thin brass coloured oil lines running along the engine casing to them. You seem to have an interesting handling package there....... 'and the arse end trying to overtake under heavy braking' , I should get your brakes and geometry checked too.
Migration info. Legacy thread was 7652
Mike Horsburgh
PostPosted: Fri Aug 29, 2003 5:49 pm    Post subject: Reply with quote
It's got new calipers and discs all round - just a combination of bumpy B roads and extreme speed...maybe not being quite in line when braking...and the billies on it will probably tend to make it a little bit more skittish over the bumps
geometry might be worth a look tho - just to make it behave a bit more
...I'll have a look for the oil lines...ta!
Mike
Migration info. Legacy thread was 7656
bones
PostPosted: Fri Aug 29, 2003 6:06 pm    Post subject: Reply with quote
Just beacause it's got new disks and calipers all round doesn't mean it should brake like a snake. OK if you brake on an uneven surface things might get a bit hairy (catches me out too down the country lanes) but if you think the behaviour is not what you would expect from a Porsche you are probably right. In your area Autofarm and JZ are the experts and fair .
Migration info. Legacy thread was 7657
James Ball
PostPosted: Fri Aug 29, 2003 7:27 pm    Post subject: Reply with quote
Mike, Give us some more details on your car - colour etc. Is it the red one from the North East?
Cheers, James
Migration info. Legacy thread was 7659
____________
'89 964 C2
Mike Horsburgh
PostPosted: Fri Aug 29, 2003 11:52 pm    Post subject: Reply with quote
Nah...white...been in the south east all it's life
Used to belong to Keith Ripp (British Rallycross Champ several times) in the early 80s, then by a bloke in High Wycombe who had it 18 yrs, and sold it to the people I bought it from. They have 18 classic cars, so hardly used it.
It's done 100k Miles on it's original engine and box (still got the original owners handbook with the same numbers in it), which haven't been rebuilt, but don't smoke or crunch. It seems to be pretty standard and original and is immaculate apart from the odd stone chip. I think it's still got all its original panels and paint. Been mollycoddled all its life and the result is it's remarkably well preserved.
It'll be on the Carrera 2.7 and 3.0 stand at the Porsche Club do this weekend if you're there.
Mike
Migration info. Legacy thread was 7675
