wind screen washers
Singh
9 Jun 2003
22
Hi, I'm not getting any water through when I pull the lever, however I can here the motor buzzing. Any help pls?, where is the motor?
thanks
Amo911 1977
Migration info. Legacy thread was 6518
Amo,
I think the motor will be down next to the battery in the luggage compartment. If you can hear it working though, I'd be checking the pipework in case it has been dislodged somewhere.
I also think there are non-return valves along its lengh, so possibly they have become stuck closed?
Do the headlamp washers and intensive washers work?
Migration info. Legacy thread was 6523
I had the same problem recently.
No dislodged pipes, so replaced the two valves (one "L" and one "T" shaped) which are found under the nozzles - and everything OK again.
A common problem according to Guildford OPC, who charge about £7 for the parts & new clips.
Migration info. Legacy thread was 7162
124,588
1,441,781
49,012
Milno
