997 : 2004- 87
996 : 1997-2005 43
Boxster : 1997- 14
Cayman : 2005- 15
Cayenne : 2003- 7
Macan : 2014- 0
sean smith
PostPosted: Fri Jul 11, 2003 12:01 pm    Post subject: Reply with quote
I have a 72 911t and the trottle linkage is binding up causing it to run wide open, I can 'reset' it from the engine I think it is catching under the rear seat. Is there an easy way to get to that part of it?
Migration info. Legacy thread was 6022
bones
PostPosted: Fri Jul 11, 2003 3:15 pm    Post subject: Reply with quote
I'm not sure about a '72 911 but on only slightly later models there is a removable metal plate under the carpets and fitted centrally behind the front seats . You might also look at the throtle linkage fastened to the gearbox and check the shaft there for any 'sticktion' . The other area apart from the engine bay is in the peadal box , easy to inspect in there once you have removed the carpet surround . It slides over the pedals .
Migration info. Legacy thread was 6030
