Bang goes the cap
oldcatbreath
3 Jan 2003
1
Hi All
1976 2.7 targa.
When starting cold it often blows the black breather cap off (complete) inside the air filter.
I then have to replace the cap (securely) and everything is OK.
Anybody any ideas?
Do I need to glue the cap in it seems secure although it seems to be a push fit.
Migration info. Legacy thread was 866
That sounds like a pretty serious backfire and is not normal, I would say. The "breather cap" you refer to sounds like a pop-off valve of sorts. These are normally glued in place and are spring-loaded. However, you should not have so many major backfires. What is your starting routine? You should avoid touching the accelerator until after the car has fired up.
Also, you should have a perfect seal around the pop-off valve. If not you might experience other problems.
Cheers, James
Migration info. Legacy thread was 868
I suggest getting your ignition timing and fuel mixture checked , if you can't do that yourself find a word of mouth good Independent mechanic . I recommend Autostrasse in Coggeshal Essex.
Migration info. Legacy thread was 1373
124,604
1,442,013
49,037
PC Saros
