911 heat exchangers
melox
9 Oct 2002
21
I have a 911 carrera 1981 which requires new heat exchagers and exhaust would it be best to fit stainless and if so where is the best place to obtain the parts .
Any help appreciated
Migration info. Legacy thread was 165
Hi Melox
Generally most people agree that the best stainless steel exhaust for the 2.7 and 3.0 engines is made my a company called SSI. They are not cheap although no stainless steel exhaust is.
By the way, there was no "911 carrera" in 1981. The only 911 produced that year was the SC. Is this the one you have? Alternatively from 1984 to 1989 the 911 was called the Carrera 3.2. SSI's will work on these t0o athlough aparently SSI's are a bit restrictive for the 3.2 engine.
Cheers, James
Migration info. Legacy thread was 166
Melox
Another company in the UK I have read good things about is "Hayward & Scott". They build taylor-made stainless steel exhausts and will taylor them to your sound-level tolerances!
James
Migration info. Legacy thread was 171
Alternatively if you can find them, you can fit a pre-'74 system I believe (the design of which is used in SSIs) although these are not stainless.
If you can find the cash (SSIs are about £1200 I believe) stainless is the way to go though.
Migration info. Legacy thread was 172
try
www.design911.co.uk
mine's a sports version 84mm £325 + vat
maybe a bit noisey for some but i'm sure they will have others!
regards
steve
Migration info. Legacy thread was 186
I have decided to go for a stainless and have got a price for a custom fit from a company in bristol called longlife,they will also fit the heat exchangers if i provide them .
Thanks to all for help i am new to the porsche and 911 site so will be on the mesage board again with next problem ?
Will post mesage when exhaust fitted to let you know results.
Mark
Migration info. Legacy thread was 187
124,563
1,441,539
48,977
GT3161
