997 : 2004- 63
Carrera SC : 1977-1983 3
Boxster : 1997- 29
Cayman : 2005- 22
Macan : 2014- 7
ViciousViper
PostPosted: Thu Mar 26, 2020 10:38 am    Post subject: ABS reluctor ring - where to buy? Reply with quote
I might have a case of a broken ABS reluctor ring (not confirmed yet).
If I need to replace it, where can I get a hold of a new one?
'99 996 Carrera 4 / 3.6 X51 Aero Cup - Arctic Silver
UncleP
PostPosted: Thu Mar 26, 2020 7:30 pm    Post subject: Reply with quote
https://www.reluctorrings.com
Bought a front one from them about a month ago. Good quality, good fit.
ViciousViper
PostPosted: Fri Mar 27, 2020 11:58 am    Post subject: Reply with quote
Thanks! Did you have to heat yours when installing?
UncleP
PostPosted: Fri Mar 27, 2020 7:45 pm    Post subject: Reply with quote
I heated it up with a crappy butane blow torch so it probably didn't give too much expansion. Used a drill wire brush to clean up the surface on the end of the CV, applied a tiny smear of grease and gently tapped it on using a drift.
It was an easy job. Took about 10 minutes including removing the old one which in my case was just badly corroded rather than split.
