997 : 2004- 63
Carrera SC : 1977-1983 3
Cayman : 2005- 23
Macan : 2014- 7
TV8
PostPosted: Tue Mar 24, 2020 9:05 pm    Post subject: Thoughts on this? Reply with quote
I had my car MOTd today and received an advisory on the near side front fixed brake pipe into the calliper. I haven't really seen something like this before and the tester suggested it needed to be properly cleaned back with a light wire brush, some protective coating and all would be good.
Your views appreciated.
Thanks in advance
2000 996 Coupe
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Tue Mar 24, 2020 9:17 pm    Post subject: Reply with quote
You could do that, but they are cheap as chips and pretty easy to change. I'd change it.
Paynewright
PostPosted: Tue Mar 24, 2020 9:29 pm    Post subject: Reply with quote
I’ve changed all four on mine and the fitting into all the callipers were severely corroded. I had to use quality mole grips (irwin vicegrips) to get them out.
Also, if they are bad then others are likely to be bad too. I just changed the last 3 original exposed rigid pipe on mine and the rear near side was shocking - usually covered by underbody protection so hidden.
 Filesize:  305.2 KB
 Viewed:  478 Time(s)
2much
PostPosted: Tue Mar 24, 2020 11:03 pm    Post subject: Reply with quote
If you put a protective coating on anything heavier than light dusting of aerosol paint, you will get an advisory along the lines of "brake lines not checked as covered with grease or other material".
Had this on Beetle where I wire brushed and painted them and Range Rover had a factory fitted shield for protection off road - advisory very year from first MOT!
The current Advisory system is not helpful at all.....unless you are a prospective buyer who can now check the .GOV web site....
MisterCorn
PostPosted: Tue Mar 24, 2020 11:12 pm    Post subject: Reply with quote
Wire brush, penetrating oil, decent brake spanner. The flexible pipe couplings can be a pain but that might mean a new bracket if rusty and a flexi pipe. Then another 20 years without advisories.
kurlykris
PostPosted: Tue Mar 24, 2020 11:23 pm    Post subject: Reply with quote
I won`t post a picture of mine on the 996 then, you would probably have a heart attack if you saw the state of them...............just got a fresh MOT though Surprised
2006 987.1 Boxster S 3.2 sport chrono
2010 Mercedes E350 AMG Sport
