997 : 2004- 63
Carrera SC : 1977-1983 3
Cayman : 2005- 23
Macan : 2014- 7
dc2100k
PostPosted: Tue Mar 24, 2020 12:14 pm    Post subject: 996 C2 Rear Brake Noise Reply with quote
Hello All, just woke my 996 C2 3.6 up from its slumber and took her out for a 30 mile run to shake off the cobwebs. Can is running beautifully but there is a bit of a light rubbing noise coming from the rear brakes that hasn’t disappeared after the run. Can was last moved about six weeks ago and was garaged with the handbrake off all that time.
All the discs had done very light surface rust on them before I took the car out and after the run the fronts are clean but the rears are still have a bit on parts and the disc surface isn’t perfectly flat - do I need to get these skimmed? The handbrake seems to work fine btw.
Any advice appreciated.
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Mar 24, 2020 12:26 pm    Post subject: Reply with quote
It could well be some light corrosion on the inside surface of the rear discs. It should go with time... may be try a series of very hard stops and see if that improves things.
Check also that there is no undue heat coming from the wheels/discs after a run which might indicate a calliper binding.
