997 : 2004- 63
Carrera SC : 1977-1983 3
Cayman : 2005- 23
Macan : 2014- 7
ian_alex
PostPosted: Mon Mar 23, 2020 6:02 pm    Post subject: Oil Change Reply with quote
I am going to change the oil on my friends 997 Gen 2, 2009 car and am wondering if there is anything special or tricky involved.
I am very familiar with my own 996 on which I do all the servicing and I am presuming my friends is similarly straightforward although I haven't yet looked at filter location etc on it.
Looks like Mobil 1 0w40 is required? Low mileage car, approx 30K
Thanks for any advice.
PostPosted: Mon Mar 23, 2020 7:03 pm    Post subject: Reply with quote
Nothing tricky but you need to leave it draining for at least 30 mins .. basically when its stops trickling out and turns into a drip then you can carry on .
No more than 7 litres of oil and run it up .. top up as required .
A short 10 min drain and it might only need 6 ltrs .. an overnight one and about 9 ltrs .
Mobil 1 0w/40 .
For the filter you will need an extension to reach it and plenty of cloth to wipe down the cross bar under it .
Indy Mechanic .
wjk_glynn
PostPosted: Tue Mar 24, 2020 1:17 am    Post subject: Reply with quote
Very nice DIY video for the 997.2 Carrera models...
https://www.youtube.com/watch?v=o_dWnmMT49w
Karl.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers
ian_alex
PostPosted: Tue Mar 24, 2020 2:46 pm    Post subject: Oil change Reply with quote
Thanks to you both for the info. Looks pretty straightforward.
I'm still waiting for the oil change where I don't get a single drop on the garage floor, don't think it will ever happen!!!
