997 : 2004- 63
Carrera SC : 1977-1983 3
Cayman : 2005- 23
Macan : 2014- 7
Kp76
PostPosted: Sun Mar 22, 2020 3:49 pm    Post subject: Rear tie rods Reply with quote
I've just replaced both left and right rear tie rods and eccentric bolts, after the replacement went to have the wheel alignment checked out but there isn't enough adjustment to get rear wheels within tolerance. The chap said there within 3mm but i fear its going to scrub my tyres pretty quickly, its a gen 1 3.8 Carrera 2S, 04. Part number 4160500007.
Is there something wrong with the parts or is everything else worn out.
Newbe
PostPosted: Sun Mar 22, 2020 4:33 pm    Post subject: Reply with quote
I had 4 wheel alignment done a few weeks ago after replacing my front coffin arms and tuning forks. I took it to an indie who deals with Porsche.
He asked me what make I used as he had seen some recently which were a couple of mm too big. He said they would fit ok but the alignment couldn’t be done.
The ones I fitted were ok and my alignment was perfect.
I wonder if there’s something wrong with the parts fitted?? Only a thought based upon what the indie told me.
Where did they come from??
Kp76
PostPosted: Sun Mar 22, 2020 7:09 pm    Post subject: Reply with quote
I used Meyle, thinking they are a good brand
PostPosted: Sun Mar 22, 2020 7:21 pm    Post subject: Reply with quote
https://www.deroure.com/diagrams.asp?TBL=2821&MAK=3&MDL=26&SMA=0&SMO=0&ST=&SC=0
No. 13 here .. it says model year 2006 onwards .. this is the part number of what you have but your car is a 2004.
I would suggest phone an OPC on Monday .. get a price and the part number and confirm this is the correct part for your car .. they will want your chassis number to look it up .
Aftermarket items are not always the same as OEM .
Indy Mechanic .
