997 : 2004- 63
Carrera SC : 1977-1983 3
Boxster : 1997- 29
Cayman : 2005- 22
Macan : 2014- 7
Ishay
PostPosted: Tue Mar 17, 2020 11:00 am    Post subject: Stuck Headlight Switch (MOT Fail and Easy Fix) Reply with quote
Hey, just had my 997.1 Turbo fail an MOT on the inability to pull out the headlight switch for the fog lamps. Had noticed the headlight twist was tight but hadn't needed the fog lamps to notice.
Still if you get it, it's a super easy fix:
1) Push in and twist to remove the switch.
2) Remove the back of the unit with a small torx bit (didn't check the size)
3) pull of the PCB carefully without bending the wiring pins.
4) re-grease the mechanism
5) re-assemble
easy. £70 part saved and no labour.
Current: 997.1 Turbo, Coupe, Manual
Current: BMW X1 2.0d
Previous: 997.2, Coupe PDK
Ishay
PostPosted: Tue Mar 17, 2020 11:15 am    Post subject: Reply with quote
Also pleased to say that in the past 2 years (at 13&14 years old) that's the only fail I've had!
PostPosted: Tue Mar 17, 2020 7:20 pm    Post subject: Reply with quote
Interesting , i've not seen this before but if i had i would probably have just fitted a new switch .. cheers for the heads up young man Thumb
Indy Mechanic .
