997 : 2004- 63
Carrera SC : 1977-1983 3
Boxster : 1997- 29
Cayman : 2005- 22
Macan : 2014- 7
berni29
PostPosted: Mon Mar 16, 2020 5:12 pm    Post subject: Spotlamp housings, chroming and LED DRL's Reply with quote
Hi
I have had my spotlamp housings chromed, and want to convert my spotlamps to LED DRL's. Does anyone know which H3 LED's work well with the projectors?
By "well" I know that they do not work properly as foglamps, but will be highly visible. The ideal LED will be small with emitters on the front face, not so much the sides.......
I know you can jump the relay to make the spotlamps come on with the ignition, off with the headlamps, and on again with the switch on the dashboard for when the headlamps are on.
All the best
Berni
993 C2 Tip 1994 197k miles. Black and Grey. M029 & Bilstein HD's, Elephant Racing RS bushes F&R, RS mounts, strengthened engine carrier, 100 cell cat inserts, HID's. Solid steering arms mod, top of the engine rebuilt, mapped by Wayne, suspension set up by Chris at CG.
gunner
PostPosted: Tue Mar 17, 2020 9:25 am    Post subject: Re: Spotlamp housings, chroming and LED DRL's Reply with quote
Berni
Any pics?
993 C2 Tip Aventura
gunner
PostPosted: Tue Mar 17, 2020 9:32 am    Post subject: Re: Spotlamp housings, chroming and LED DRL's Reply with quote
Berni
Any pics?
993 C2 Tip Aventura
Endoman
PostPosted: Tue Mar 17, 2020 9:44 am    Post subject: Reply with quote
Std fogs are reflectors n'est pas? So you can use something like this :- https://www.horizonleds.co.uk/h3-25w-cree-led-fog-light.
main problem is length of bulb.
berni29
PostPosted: Tue Mar 17, 2020 5:23 pm    Post subject: Reply with quote
Hello
Here is a quick snap taken indoors in low light. I will take a better snap tomorrow. The housings will actually take quite a long bulb, but the shorter the better. I have bought the LED type that have emitters at the side and also the end. I will examine the exact mounting options when they arrive.
I will also modify the projectors themselves by removing the shields that cut the light beam from shining upwards (important to reduce upward glare when being used as fog lamps) because they will now be DRL's and not fog lamps.
All the best
Berni
 Filesize:  1.24 MB
 Viewed:  814 Time(s)
ToreB
Approved Trader
PostPosted: Tue Mar 17, 2020 10:03 pm    Post subject: Reply with quote
I have tried tons of LEDs in the front fog lights, and have found none that produce the correct light output pattern and intensity compared to the original H3 lamps. I have thought of finding a LED-based lamp with lens instead of the original projector lens construction, but have not found the time or inspiration to do this.
Cheers,
Tore
'95 993 C4
Bergvill F/X
Porsche electronics specialists, products and repair services.
Tobesetc
PostPosted: Wed Mar 18, 2020 11:08 am    Post subject: Reply with quote
Tore is correct, it's very difficult to make an LED "fog light". When I put the vented front on (RS-style) I wanted to keep the side light + fog light capability by putting both into the new single unit using LED. But the bottom line is that the fog light element is a pale imitation (what a pun!) of the old style bulbs. See pic for how it was done and what it looks like.
I'm happy because I never actually use Fog lights in actual fog and now they do at least match the "blue" look of the converted headlights, rather than the very yellow look of the old side/fogs. So for me, this is a decent result.
But it ain't a proper fog light any more!
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
Photos at TobesEtc.com (work in progress)
 Filesize:  525.35 KB
 Viewed:  718 Time(s)
 Filesize:  913.41 KB
 Viewed:  718 Time(s)
Gwsinc
PostPosted: Wed Mar 18, 2020 3:16 pm    Post subject: Reply with quote
This looks great. Where did you get the caroming done??
Instagram.com/gws911
Tobesetc
PostPosted: Wed Mar 18, 2020 4:32 pm    Post subject: Reply with quote
If you're asking where was this done.... http://enigmaaudio.co.uk/contact-us/
Gwsinc
PostPosted: Wed Mar 18, 2020 8:26 pm    Post subject: Reply with quote
That’s what I meant! Chroming isn’t a word according to my iPhone...
berni29
PostPosted: Wed Mar 18, 2020 11:06 pm    Post subject: Reply with quote
Hello
Yes Tore, the current LED's available are really not suitable for foglights.
Tobestec, they look good and are great DRL's but I am keeping to the standard factory look. Apart from the clear sidelights Smile
I modified my spotlight housings to remove the shields. Before and after pictures below.....
 Filesize:  143.78 KB
 Viewed:  593 Time(s)
berni29
PostPosted: Fri Mar 20, 2020 7:46 pm    Post subject: Reply with quote
Apologies Gwsinc, Vulcan shotblasting Basildon did it. Its a chemical process, lacquer then process then lacquer. Actually they can chrome pretty much anything any colour.
I'm making progress. Glass on next. I probably should have bought new glass, but at least it will match the patina of the rest of the car.
 Filesize:  1.37 MB
 Viewed:  501 Time(s)
ianj62
PostPosted: Fri Mar 20, 2020 8:14 pm    Post subject: Reply with quote
Hi
Where did you get the converted lamp housings?
Ian
berni29
PostPosted: Fri Mar 20, 2020 10:29 pm    Post subject: Reply with quote
Hi Ian
They are standard housings. Apart from the damage sustained to them getting the lenses off that is. Some people smash the glass and spend time carefully extricating the remaining glass, but either way its a pain. The lenses are bonded to the housings with a tough grey silicone.
I bought a donor set (the originals are still on the car) as sacrificial offerings. So if it all went horribly wrong it would be ok.
Lenses are on (silicone sealant) and hopefully will fit tomorrow, make a modification to the relay and see how it works out.
Exciting times.
All the best
Berni
berni29
PostPosted: Sat Mar 21, 2020 9:06 pm    Post subject: Reply with quote
Hello again
It may not be actually possible, but I have been experimenting on getting the spotlights to work as DRL's. Removing the relay and jumping pin 3 to pin 5 in the socket for relay 31 turns the spotlights on with the ignition (good), but when you turn the headlights or sidelights on they do not go out (bad).
I want them to go out when the headlights or sidelights are on.
Anyone have any ideas?
I have fitted the chromed housings and i really like the results! Pictures tomorrow. I did sadly kill an LED sidelight removing it to change to the new housing, but hey there are always casualties in the name of progress.
All the best
Berni
Gwsinc
PostPosted: Sun Mar 22, 2020 11:13 am    Post subject: Reply with quote
Ignore - re read your post
Tobesetc
PostPosted: Sun Mar 22, 2020 12:47 pm    Post subject: Reply with quote
I like this mod - good work! Can't wait to see the finished result.
berni29
PostPosted: Sun Mar 22, 2020 4:54 pm    Post subject: Reply with quote
Hi Guys
These are the modified lights installed. Pictured in bright midday sun they seem quite good, especially straight on. I will have to try them in more dim light to make sure they are not blinding, which at night they certainly would be. Thats why they need to go off when the headlights come on.
With no lights they look so much better than the standard ones. I think normal chrome/silver spray paint is good enough to be honest, but the shinier the better.
Actually, Canadian 964's and 993's support DRL's and have a relay at r63 for that purpose. I need to find out how they are wired and recreate it.
Berni
 Filesize:  628.27 KB
 Viewed:  241 Time(s)
 Filesize:  1.08 MB
 Viewed:  241 Time(s)
 Filesize:  814.02 KB
 Viewed:  241 Time(s)
