For sale is my 993 rear bolt in roll cage, this fits sunroof and non sunroof cars and bolts in directly to the seat belt attachment points.
Bought in 2019 from Design911 for £1500
has been fitted for about 7 months and I've only driven the car about 5 times unfortunately since it has been fitted.
Car build has taken a new direction and now a full cage is going to be fitted so this is up for grabs.
I have updated the mounting hardware with new bolts all 10.9 (standard where all 10.9 but shiny steel not black ones.) and bolt head caps fitted to clean up the look.
Insulation tape was applied to the harness bar when a Gopro was trial mounted so cage is in perfect condition and zero scratches.
Looking for £1100 ono. This took around 15-20 minutes to fit, although i did have the passenger seat out at the time. shouldn't take longer than 30 minutes and really is solid. Perfect for anyone using harness and much safer than going to the rear bench or parcel shelf bolt holes.
Cage can also been seen on the Design911 website : https://www.design911.co.uk/fu/pt65...911--1994-98/993--911--C2-1994-97/Roll-Cages/
any questions please just ask
