997 : 2004- 63
Carrera SC : 1977-1983 3
Cayman : 2005- 23
Macan : 2014- 7
Bogus
PostPosted: Sat Feb 22, 2020 10:42 pm    Post subject: 991.1 C4S with Power kit and PCCB vs 991.1 4GTS Reply with quote
Hi all,
After a brief hiatus away from Porsche, the pull was too strong and I want to get back to a 911. I had a 991.1 C4S in the past and looking to maybe get a 991.1 4 GTS.
The question I have is if there is a C4S with the power kit and PDCC and PCCb would that be considered better than a 4GTS where the only difference is lack of PCCB and PDCC but has centre lock wheels ?
Are there any further differences between the 2 cars with both being PdK which would make the 991.1 GTs more desirable with all other features being the same ?
Your thoughts would be very helpful as I am struggling to make a final decision.
FZP
Reims
PostPosted: Sat Feb 22, 2020 10:51 pm    Post subject: Reply with quote
Spongebob has the 991.1 with X51. He'll be along shortly as hes currently enjoying the Sand pit in the middle east. With putting the carbon seats in his car, I think he's got a unicorn spec.
PostPosted: Sat Feb 22, 2020 11:29 pm    Post subject: Reply with quote
After much research the difference between Herman (991CS) and a GTS (at the time I purchased) was close to 20k, Herman has the PCCB, X51, PDCC and the sports design pack with ducktail.
I didn’t really want the centre locks so for me it was just the interior missing, which didn’t relate to 20K! Adding the GT2 folding buckets in my mind raised the spec above a GTS Dont know
I’ll be honest I’ve never switched the PDCC on Grin so can’t comment (reviews are very mixed) but the Powerpack makes it a GTS in my mind, if you’re looking at a 4S with Ceramics that would potentially sway it for me, the ceramics are just amazing and look amazing.
Having said all of the above if there was a GTS v a well spaced 4S for similar money I’d chose the GTS as it’s considered more desirable, so the 4S would need to be a good bit cheaper than the GTS 👍
991 C2S PDK - X51 430 Powerkit, Dynamic engine mounts, Carbon GT2 folding buckets, PCCB, PDCC, PSE, Carrera S alloys, Sports design bodykit with ducktail and Alcantara steering wheel. If Carling did a 991S...
“Herman yellow, the last of the naturally aspirated”
Bogus
PostPosted: Sat Feb 22, 2020 11:48 pm    Post subject: Reply with quote
If the well specced C4S is specced similar to the GTS by having the PDCC, powerkit, except for centre locks and a little bit cheaper would you still go for the GTS ? As the the C4S would then be marginally ahead because of the PCCBs.
I guess what I am looking for is is there so.ething more under the skin of a GTS like different steering ratios, different suspension settings like different spring rates etc apart from having a lowered car which a C4S with PASM is also the same from my understanding.
Bogus
PostPosted: Wed Feb 26, 2020 9:47 pm    Post subject: Reply with quote
Pulled the plug on a C4S with the X51 powerkit, PCCB and PDCC. Car going in for a 111 point check tomorrow. Fingers crossed. If all.is well should get it by weekend.
Mad Mark911
PostPosted: Wed Feb 26, 2020 10:32 pm    Post subject: Reply with quote
Bogus wrote:
I guess what I am looking for is is there something more under the skin of a GTS like different steering ratios, different suspension settings like different spring rates etc apart from having a lowered car which a C4S with PASM is also the same from my understanding.
Wouldn't it need to be a C4S with SPASM to have the same suspension as the GTS? I thought they were lowered over the standard models.
991.1 C2S - Rhodium Silver
Golf R - Lapiz Blue
Honda Civic Type R JDM - All white
Too many previous cars to list ...
PostPosted: Wed Feb 26, 2020 11:04 pm    Post subject: Reply with quote
Would need to be PDCC with PASM Thumb Many of the PDCC cars were specced this way.
OP sounds like a cracking spec worship
Bogus
PostPosted: Thu Feb 27, 2020 8:13 am    Post subject: Reply with quote
Yes true and as Sponge says most cars were specced tthat way including this one.
Bogus
PostPosted: Thu Feb 27, 2020 8:14 am    Post subject: Reply with quote
@spongebob did you get the car with an Alcantara Steering wheel or got it retrofitted ?
Mad Mark911
PostPosted: Thu Feb 27, 2020 8:16 am    Post subject: Reply with quote
Gotcha! Sounds sublime. I just wish mine had the Powerkit, because at the time I was looking, only the ex-Porsche Experience cars had it and there was no way I was going to buy one of those!
Golf R - Lapiz Blue
PostPosted: Thu Feb 27, 2020 10:27 am    Post subject: Reply with quote
Retrofitted by jack at Royal 👍
Bogus
PostPosted: Thu Feb 27, 2020 11:11 pm    Post subject: Reply with quote
Bad news guys.
Had the 111 point check done before I bought the car and all was fine except for a cracked rear driver side disc. One disc costs close to £4500 as the car has PCCB. The porsche technician feels would have been a small crack and developed into a big one as the customer would not have noticed it.
That was the only finding.
Should I go for the car if the rear disc is replaced ?
Bogus
PostPosted: Thu Feb 27, 2020 11:13 pm    Post subject: Reply with quote
Pic attached
 Filesize:  891.71 KB
 Viewed:  1175 Time(s)
Mad Mark911
PostPosted: Fri Feb 28, 2020 12:36 am    Post subject: Reply with quote
I never like to see the crossed drilled holes full of pad material, because someone has gotten them very hot to do that. Sad
Two thoughts:
1. The PCCB discs have 3 wear indicators embedded into to them, so what level are all the other discs at.
2. How much life is in the pads? They are expensive and start to prematurely heat up and wear the discs once they get beyond 50% pad life and if you let them go too low - they destroy the discs.
Golf R - Lapiz Blue
PostPosted: Fri Feb 28, 2020 9:15 am    Post subject: Reply with quote
Two thoughts:
🖕As above, plus if you own a car with Ceramics you would know about that damage 100%. Would be very easy to see just through general daily use, no way the owner (or dealer) wouldn’t know.
Would you just replace one? Personally I’d always change in pairs. Plus Remember the only way to check Ceramics properly is to remove them and weigh them, there’s some debate on the accuracy of the wear markers, these often show on low mileage cars.
In summary unless the ceramics are 100% you’d need a very healthy discount or walk away (for example 9 grand off my car as there was wear to the rear ceramics) (but no damage) (the fronts had clearly been replaced at some stage).
The other point on such a well specced car would be is it a press car? Quite likely with the spec, not an issue for me, but may be for some. Another possibility would be a Porsche experience car which would be a no-no for me.
maph
PostPosted: Fri Feb 28, 2020 8:51 pm    Post subject: Reply with quote
I suspect the initial damage was made taking a wheel off. As the tech said the chip was probably small and it has grown bigger. Photo is pretty low res so it is difficult to tell how much wear it/ and the other side is likely to have.
Agree that both the owner and dealer would have known about it. I would want the disc replaced with OEM (depending on the wear on the other side) or the pair refurbed before sale. Or a min of a £5k discount.
2012 997.2 Turbo S - ES650
Bogus
PostPosted: Fri Feb 28, 2020 10:49 pm    Post subject: Reply with quote
I have decided not to ho ahead. Too much risk and as a matter of principle walked away.
They should have told me about it as it is not a small.issue to not tell a potential buyer.
And they were unwilling to budge on price as they were replacing the disc.
Mad Mark911
PostPosted: Fri Feb 28, 2020 11:17 pm    Post subject: Reply with quote
Sorry to hear that - but prudence is the better part of valour.
Just tell yourself it had been hammered to hell and back - then you might feel it was a lucky escape?
Golf R - Lapiz Blue
Bogus
PostPosted: Sun Mar 22, 2020 6:43 am    Post subject: Reply with quote
Hi All,
So after the debacle with the C4S, I decided to go with the 991.1 GTS.
What a car!!!
Picked it up yesterday. Absolutely brilliant. The way it drives, the grip, the relentless power delivery and finally the noise. Simply outstanding. I could keep revving all day long.
Looking forward many happy miles with the car. Spec as follows
Rhodium Silver with Turbo S center lock wheels in Satin black and black GTS interior and red contrast stitching.
LED with PDLS
Sunroof
Adaptive cruise control
Sports Plus seats
Carbon interior
Power steering plus
Will post pics soon
Jungle650
PostPosted: Sun Mar 22, 2020 6:51 am    Post subject: Reply with quote
Welcome to the Rhodium Silver club !
Get out and enjoy it while the sun is out and there are no lock downs on movement!
Jungle
Laughing
991.1 C4S
Full Xpel Ultimate PPF
And loving it !!
