997 : 2004- 56
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
4076simon
PostPosted: Fri Feb 14, 2020 8:00 pm    Post subject: 996 C4S ring of rust on front discs Reply with quote
Had my 996 C4S since September. Always thought a long drive with some enthusiastic braking would get rid of ring of rust on discs. Just driven 150 miles to Devon where she’s going in for some paint and the rust ring about 1 inch deep down from circumference is still there. Previous owner put new callipers on, Something is not right. Any thoughts? Thanks!
2002 996 C4S Lapis Blue
 Filesize:  1.96 MB
 Viewed:  650 Time(s)
kas750
Shanghai
2006 Porsche 911
PostPosted: Fri Feb 14, 2020 8:02 pm    Post subject: Reply with quote
You may get rid of that if you fit new pads or cane the arse off it for a while.
No rustys rings on any of my cars Hand Very Happy
PostPosted: Fri Feb 14, 2020 8:05 pm    Post subject: Reply with quote
Looks like the wrong pads are in for those discs/calipers. Pad should run out all the way to the edge of the disc......and it isn't. Dont know
DarthFaker
PostPosted: Fri Feb 14, 2020 9:22 pm    Post subject: Reply with quote
Deffo something wrong there. Mine are shiny all the way.
kurlykris
PostPosted: Fri Feb 14, 2020 10:01 pm    Post subject: Reply with quote
Definitely something not right there 4076simon, you should have a very small lip of maybe 2mm wide at the circumference of the disk and another on the inner diameter as the disk face meets the weather groove around the top hat diameter. Here is a photo of mine on the Boxster the day I swapped them all for new ones Thumb
2006 987.1 Boxster S 3.2 sport chrono
2010 Mercedes E350 AMG Sport
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Sat Feb 15, 2020 12:38 am    Post subject: Reply with quote
When you say new callipers, did they fit the right ones? Are they the Turbo spec ‘big reds’?
4076simon
PostPosted: Sat Feb 15, 2020 9:30 am    Post subject: Reply with quote
Thanks Guys, previous owner has now assured me that new callipers were exchanged recon C4S/turbo , so we’ll change pads and go from there. Can’t think discs would be too big?
911Time
PostPosted: Sat Feb 15, 2020 11:09 am    Post subject: Reply with quote
The disks can't be too big.
I would remove one of the existing pads, check the surface of the pad for even wear then measure the width of the pad, next measure the swept area on the face of the disk - obviously it should match - if not they're the wrong pads. Simples. Very Happy
Mark
I'm not a perfectionist - I just want everything done 'Right' Wink
Current: GT Silver 991.1 C4S with a few 'special bits'. Previous Owned: C63 Estate, BMW e92 330d Coupe (700Nm/Custom Exh/Map/BBK/Quaife/Breytons), ML63AMG, Alpina e46 B3S Coupe, Alpina e36 B3 Coupe, Lotus Excel SE, Alfasud Green Cloverleaf Ti, Lancia HPE, Capri 2.0S, Marina 1.8 (don't laugh it was my first road car). Bikes: Suzuki TL1000R and BMW R1100S AC Schnitzer.
Gray79
PostPosted: Sat Feb 15, 2020 12:50 pm    Post subject: Reply with quote
This thread has come up just as I have got mine back from mot and service, they changed the front pads and I have exactly the same around the outside of my discs. I have checked the part number of the pads they used, and they should be correct for the car. I haven’t had chance to take the wheels off and have a look what is happening yet. Dont know
997.1 Carrera 2S
Teffers
PostPosted: Sat Feb 15, 2020 4:44 pm    Post subject: Reply with quote
I changed pads all round last week. One of the fronts had started to break up - tell tale sign was band of rust on the disc there there was no pad surface to make contact!
Tracktard. French obsession.
 Filesize:  1.04 MB
 Viewed:  355 Time(s)
