997 : 2004- 63
Boxster : 1997- 25
Cayman : 2005- 20
Macan : 2014- 3
wilsonny
PostPosted: Wed Feb 12, 2020 8:10 pm    Post subject: blower experience ? Reply with quote
so im deep into replacing the evaporator on my car (write up to follow) and one of the obvious "while your in there" jobs is to replace the two heater blowers. not doing so would be a bit crazy given the amount of effort to get here and the likelihood that these will be showing their age.... they are covered in debris.
oem replacements are hugely overpriced, but certain online suppliers have dansk versions for a more sensible price. but is it false economy ? anyone got any experience of these units ?
1996 C2 manual
Croydon
PostPosted: Thu Feb 13, 2020 7:36 am    Post subject: Re: blower experience ? Reply with quote
I've ordered yesterday both L and R Danske units and the two pack pollen filters. Pelican parts have a very good step by step photographed instruction including the removal of the fuel expansion tank to get to the LHD unit. that initially worried me.
I'm not exactly the DIY mechanic type but after reading up and going over all the aspects of the job a few times I feel confident enough to be able to take my time and get this done over the weekend.
https://www.pelicanparts.com/techarticles/Porsche-993/59-ELEC-Front_Blower_Motors_Replacement/59-ELEC-Front_Blower_Motors_Replacement.htm
https://www.pelicanparts.com/techarticles/Porsche-993/58-FUEL-Fuel_Expansion_Tank_and_Rollover_Valve_Replacement/58-FUEL-Fuel_Expansion_Tank_and_Rollover_Valve_Replacement.htm
(up to figure 9)
hope that helps
Ian
decgraham
PostPosted: Thu Feb 13, 2020 8:09 am    Post subject: Reply with quote
Don't know what the Dansk motors cost but just found these after a search, don't seem too bad compared with original Porsche. No affiliation.
https://www.partworks.de/partworks-de-porsche-993-94-98-2-geblaesemotoren-fuer-porsche-964-993-mit-luefterrad.html
ATB Smile
Croydon
PostPosted: Thu Feb 13, 2020 8:15 am    Post subject: Reply with quote
decgraham wrote:
ATB Smile
Good value actually ;
https://www.design911shop.com/Porsche-964-993-Heater-blower-motor--96457201501--96457201601/prod4693/
Croydon
PostPosted: Thu Feb 13, 2020 8:16 am    Post subject: Reply with quote
Filters (2) are cheap also ;
https://www.design911shop.com/Pollen-Particle-Filter-Porsche-993-1994-97_2/prod3893/
ToreB
Approved Trader
PostPosted: Thu Feb 13, 2020 9:20 am    Post subject: Reply with quote
I agree on changing the blower motors while in there. I have used the Dansk/JP Group motors myself, they are excellent.
I would also consider to change the fresh air servo too, it will most likely give up the ghost anyway. However, it is easy to change the servo after reassembly. This part is also crazy overprized at Porsche, (about EUR400?) I refurbish them and change all internal parts at a significantly lower cost.
Cheers,
Tore
'95 993 C4
Bergvill F/X
Porsche electronics specialists, products and repair services.
Croydon
PostPosted: Thu Feb 13, 2020 9:46 am    Post subject: Reply with quote
Cheers,
Tore
Torre hi please PM me with some info. I've already ordered your climate control unit (last weekend).
Ian
wilsonny
PostPosted: Thu Feb 13, 2020 3:00 pm    Post subject: Reply with quote
thanks for the pointers guys... ive also gone ahead now and ordered the dansk units and it now looks like I need to avail myself of further services from torre !
here's a little pic of the point ive reached, just before I had cracked open the cassette. ive avoided removing the wiring from the inside of the car. from this point the cassette splits in half and you can take the piece with the evaporator away from the car.
notice how handy your wife's table protector material can be to this job...
[img]https://photos.app.goo.gl/qyUwS8VyksN6EqmK6[/img]
1996 C2 manual
Croydon
PostPosted: Thu Feb 13, 2020 3:11 pm    Post subject: Reply with quote
Link no worky Sad
wilsonny
PostPosted: Thu Feb 13, 2020 3:19 pm    Post subject: Reply with quote
I'll try that pic again....
[img]
[/img]
1996 C2 manual
Croydon
PostPosted: Thu Feb 13, 2020 4:27 pm    Post subject: Reply with quote
[img]
[/img]
Good work,
Q.
Why have you detached the whole unit? Are you changing more than just the two fan units?
Also how did you get on with the expansion tank removal?
Ian
wilsonny
PostPosted: Thu Feb 13, 2020 4:54 pm    Post subject: Reply with quote
Croydon wrote:
[img]
[/img]
Good work,
Q.
Ian
yeah... im doing the FULL a/c job... so new evaporator, expansion valve, ccu overhaul and new fan by torre, new compressor, condenser and dryer.
my compressor seized on the motorway 18 months or more ago, so this most likely threw rubbish around the system so I needed to replace the expansion valve. my condensor is falling apart... so I just decided I'd do it all.
expansion tank is quite easy....I followed the usual instructions pointers from Torre site...I have some notes I'll post at the end on the general job but the only thing about the expansion tank is realising the rubber unit on top just pushes forward... it's not in the tank as such. getting to the expansion valve is not too bad...if you go down the full route, getting the cassette out is a horrid job. im very fortunate to have a lift, which definitely makes things easier.
1996 C2 manual
wilsonny
PostPosted: Thu Feb 13, 2020 5:06 pm    Post subject: Reply with quote
here's a pic of the rubber attachment dislodged from the expansion tank
https://photos.app.goo.gl/r7p8RV6sXT5Ztjdr8
another thing is when trying to get the hoses off, it makes a massive difference if you lift a corner of the tube and squirt some silicone lubricant in... this really helps free the rubber hose from the plastic tank fittings.
1996 C2 manual
Croydon
PostPosted: Thu Feb 13, 2020 5:10 pm    Post subject: Reply with quote
Great thanks
My parts arrived today so you should get your new fans/filters tomorrow id say. Good to see you've also got limited work space inn your garage like me.
Ian
wilsonny
PostPosted: Thu Feb 13, 2020 5:24 pm    Post subject: Reply with quote
Ian
good stuff
space wise, its certainly JUST enough and no more Smile
https://photos.app.goo.gl/HRKX1yaKKQZ2u7hF8
https://photos.app.goo.gl/ZRN93TEPED6hwNFT7
https://photos.app.goo.gl/zpBMwrPAQdwvtzmT6
1996 C2 manual
