997 : 2004- 63
Boxster : 1997- 25
Cayman : 2005- 20
Macan : 2014- 3
Powelly999
PostPosted: Sat Feb 08, 2020 10:33 pm    Post subject: Looking for a 997 Reply with quote
Hi all
Second post ever on here, but had to say something about going to see a 997 as a first time Porsche buyer today. I’ve not got a great budget, but a car local (ish) to me in Cardiff seemed to have most of the spec I want. Arranged to view this morning and arrived to find the unit full of most desirable vehicles, Bentleys, Ferrari’s, Porches etc. The owner introduced himself and showed me the car, at the back with three cars in front and parked between two other 997’s, an C4S, and a C2S cabriolet. He promptly handed me a file of history with OPC and specialist servicing receipts, mot printouts to read through especially the list of engine parts on a bill from Reading Porsche if I remember correctly, with a number of other receipts making up the cars full history folder. After 10 mins or so of studying these, mostly looking at the engine work by Reading to check the repair of a bore scoring issue, I noticed that it was referring to a car with a private plate and different to the one on the car itself. I also noticed that one of the advisories on one MOT mentioned that the VIN number on the windscreen was obscured and unreadable. At this point I wandered over to the car, to look for myself but no offer to move the car out for a proper look was offered. It was parked so close to the other two it was impossible to even open the doors and I almost felt a nuisance asking if it could be done! While I was looking at what I could in situ, running my hand over the paintwork, I felt imperfections like dust had settled on new paintwork after painting but not sure how good standard Porsche finishing was although it’s surely better than I was feeling?
Anyway I won’t bore you anymore but I walked away, slightly disappointed I’d wasted a morning as it seemed the paperwork file could have been from a different car, it had all the hallmarks of a complete respray, a new windscreen which the mastic used covered the VIN, and I also noticed that one headlight seemed newer than the other due to the lense being crazed and slightly discoloured.
So in a nutshell, without even putting a key in the ignition even if I could have opened a door, it felt wrong!
This was my first step in looking for a 997 and to be honest a bit worrying as to if this is what my Porsche quest will be like, surely not?!
Regards, and a little wiser.
Andrew (without a 997)
PostPosted: Sat Feb 08, 2020 10:42 pm    Post subject: Reply with quote
Bad luck Rolling Eyes
Was it a dealer then Dont know
Sounds a bit odd, got a link to the car Confused
Powelly999
PostPosted: Sat Feb 08, 2020 10:53 pm    Post subject: Reply with quote
PM’d you
Ratattak
PostPosted: Sat Feb 08, 2020 10:58 pm    Post subject: Reply with quote
PM'd you
 Filesize:  1.64 MB
 Viewed:  782 Time(s)
PostPosted: Sat Feb 08, 2020 11:10 pm    Post subject: Reply with quote
You can post a link up here Smile
His advert says:
"The vehicle has already had the benefit of having its bore scoring done by Porsche at approx 50k which is most definitely noticeable which complements the car and combing it’s full service history (last serviced just under taken). So already to drive away. (This is not a nasty stone chip example nor suffering from dimple dents or car parking dents scuffs ."
Grin Bandit
PostPosted: Sat Feb 08, 2020 11:14 pm    Post subject: Reply with quote
STOP PRESS Judge Cop
This guy is the one that was on Rogue Traders!!!
https://www.cardealerreviews.co.uk/dealership/the-orion-solutions-cardiff-glamorgan-wales
Andrew Williams of Williams Motors Bandit
Surprised
PostPosted: Sat Feb 08, 2020 11:25 pm    Post subject: Reply with quote
Found the thread:
http://911uk.com/viewtopic.php?t=68184&highlight=rogue+traders
Powelly999
PostPosted: Sat Feb 08, 2020 11:55 pm    Post subject: Reply with quote
Ahhhh seems like my instincts were right!
Thank you
max_b
PostPosted: Sun Feb 09, 2020 10:28 pm    Post subject: Reply with quote
Andrew/Powelly999, what's your budget?
Basalt 997 c2s
resigner
PostPosted: Tue Feb 11, 2020 5:56 pm    Post subject: Reply with quote
"he vehicle has already had the benefit of having its bore scoring done by Porsche at approx 50k which is most definitely noticeable "
Definately noticeable.
***** ALERT!!!!!!!!
Cannop
PostPosted: Wed Feb 12, 2020 12:06 pm    Post subject: Reply with quote
^^^ The only saving grace is he can actually spell definitely Mr. Green
Full fat Hartech'd C2S Manual
Ishay
PostPosted: Wed Feb 12, 2020 12:19 pm    Post subject: Reply with quote
Maybe his others blow so much soot out the back that it's noticeable that this one doesn't Grin
Current: 997.1 Turbo, Coupe, Manual
Current: BMW X1 2.0d
Previous: 997.2, Coupe PDK
