997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 24
Cayman : 2005- 22
Cayenne : 2003- 7
Matrixxxx
PostPosted: Fri Feb 07, 2020 9:16 am    Post subject: Petrol engine sounding like a diesel? Reply with quote
My 4.8L petrol engine is making a noise during acceleration that sounds like the injectors on a diesel, mixed with a boost leak sound (but no turbo), I'm thinking an exhaust leak rather than cylinder head valve timing noise?
Current Cars
2008 Lexus ISF,
2009 Cayenne GTS
golfprorich
PostPosted: Fri Feb 07, 2020 3:37 pm    Post subject: Reply with quote
Can you make a recording of the sound? Will it happen if stationary and you hold the revs?
Cayenne S 4.5 V8
PostPosted: Fri Feb 07, 2020 7:57 pm    Post subject: Reply with quote
As per Richards comment .. sound clip if possible and a fault code read of the dme to help us .
Exhaust leak .. tappets .. piston slap .. it's a guess atm i'm afraid .
Indy Mechanic .
Matrixxxx
PostPosted: Mon Feb 10, 2020 12:05 pm    Post subject: Reply with quote
I will try to record it, although it is one of those sounds that only I can hear, I can only hear it on load and no sound in sports mode , and it goes when not in sports mode when you reach the rev's where the sports flap opens, which is why I was going down the exhaust leak route, just wondered it they were prone to cracking, or joint leaks?
Current Cars
2008 Lexus ISF,
2009 Cayenne GTS
MarkGolf
PostPosted: Tue Feb 11, 2020 3:33 pm    Post subject: Reply with quote
Check the flexi joints on the primary cat down pipe, they're a weak spot. Someone had wrapped mine, not sure if it's covered a weak point or for protection.
Current fleet
1991 964 Carrera
2005 997 Carrera S
2008 957 Cayenne GTS
2003 Boxster 2.7
1991 Mercedes 500SL
1979 Mercedes 280e
1995 VW Golf VR6 3.0
