997 : 2004- 63
Boxster : 1997- 25
Cayman : 2005- 20
Macan : 2014- 3
Grey996
PostPosted: Thu Feb 06, 2020 10:42 am    Post subject: I bet you’ve not seen this before! Reply with quote
The car is in at Revolution to fix the gearbox detent arm I posted about before Christmas. While the box was out I asked them to check the IMS, they found that it had been done before, they’d used a part they weren’t familiar with and that it was caked in black sealant to stop it leaking, which hadn’t worked!
I suppose I’m lucky it hadn’t gone in the three years I’ve owned the car but it might be time for a new one!
2002 Porsche 996 C2
 Filesize:  1.5 MB
 Viewed:  1155 Time(s)
wasz
Paul Ricard
1999 Porsche 996 Carrera 2
PostPosted: Thu Feb 06, 2020 12:41 pm    Post subject: Reply with quote
Many of the supposed "RMS" leaks are actually leaks from the IMS bearing cover. The seal isn't very good.
I suspect someone replaced the IMS bearing and the customer came back as there was a leak.
Then they fudged loads of sealant on it rather than remove and reseal.
996 parts cache sell off
Grey996
PostPosted: Thu Feb 06, 2020 4:45 pm    Post subject: Reply with quote
You’re probably right, it was a bit of a shock though especially as my bill quadrupled!
2002 Porsche 996 C2
Griffter
PostPosted: Thu Feb 06, 2020 5:17 pm    Post subject: Reply with quote
Yeah but maybe a silver lining to the gearbox faux pas. Imagine the bill if the IMS bearing had gone pop.
Grey996
PostPosted: Thu Feb 06, 2020 5:24 pm    Post subject: Reply with quote
For sure, I think was definitely on borrowed time!
2002 Porsche 996 C2
wasz
Paul Ricard
PostPosted: Thu Feb 06, 2020 5:34 pm    Post subject: Reply with quote
Was the bearing itself worn? Play in it or not smooth to turn?
Marky911
PostPosted: Thu Feb 06, 2020 8:47 pm    Post subject: Reply with quote
My C2 was similar.
Not the best looking solution but as Wasz says they’re notorious for leaking, so an additional sealant applied at point of installation isn’t a bad idea.
My Indy prefers a squirt of apple sauce and some monkeys blood. Very Happy
Also just to mention. The state of the outside of the cover is no way related the the bearing it supports. IMS cover isn’t IMS bearing. Thumb
adamw
Estoril
1998 Porsche 996 Carrera 2
PostPosted: Thu Feb 06, 2020 9:52 pm    Post subject: Reply with quote
Very glad to hear it Very Happy
98’ 996 C2 aero, Swartz Black, GT3 style fixed buckets, GT3 momo steering wheel, GT3 wheels, KW’s + lots more
EX : 02' 996 Turbo Coupe ( May 17 - Sept 19 )
Grey996
PostPosted: Fri Feb 07, 2020 10:24 pm    Post subject: Reply with quote
I haven’t heard back yet.
2002 Porsche 996 C2
Grey996
PostPosted: Fri Feb 07, 2020 10:29 pm    Post subject: Reply with quote
Good point, I’ll just have to trust the garage to assess things and advise once it’s tidied up.
2002 Porsche 996 C2
Grey996
PostPosted: Thu Feb 13, 2020 10:52 am    Post subject: Reply with quote
Picked the car up yesterday and it’s soooo good. IMS, RMS and new clutch, plus full gearbox overhaul, new selector arm and all linkages properly adjusted. Wheel alignment also all done properly and the steering is now much lighter. Very pleased indeed and much better than the heavy clutch and steering I’d gotten used to over the last few years.
2002 Porsche 996 C2
