997 : 2004- 63
Boxster : 1997- 25
Cayman : 2005- 20
Macan : 2014- 3
Tappy
PostPosted: Wed Feb 05, 2020 1:28 pm    Post subject: 993 speakers Reply with quote
Hi guys, does anyone recommend a supplier for speakers AND GRILLS for a 993 , reasonable quality , don't have to be top end I'm buying one which have had them removed ( REAR RECTANGULAR AND ROUND DOOR ) tweeters still intact
Croydon
PostPosted: Wed Feb 05, 2020 3:35 pm    Post subject: Re: 993 speakers Reply with quote
id be interested too, my circular door ones are after market and too large (too big for the door bin).
ch3tman
1995 Porsche 911
PostPosted: Wed Feb 05, 2020 8:21 pm    Post subject: Re: 993 speakers Reply with quote
Have a look here:
http://911uk.com/viewtopic.php?p=1407300#1407300
and here:
http://911uk.com/viewtopic.php?t=95754
and here:
http://911uk.com/viewtopic.php?t=97193
You can get discreet crossover installs and discreet/unbranded grills, example below:
Photos | instagram.com/ch3tman
H0ME
PostPosted: Fri Feb 07, 2020 6:14 pm    Post subject: Reply with quote
Bought mine from Gert/Carnewal. The fit is good and the grill looks standard. There is a little badge I think can be removed.
Gwsinc
PostPosted: Mon Feb 10, 2020 11:24 am    Post subject: Reply with quote
The old aftermarket MB QUARTZ speakers in my C2 have started playing up and shorting out, I think because of water getting into the back of the speakers. I’ve bought a set of coax Alpine speakers for the doors and parcel shelf from amazon and some waterproof covers for the rear of the speaker.
Will post some photos later this week once installed.
Instagram.com/gws911
Tobesetc
PostPosted: Mon Feb 10, 2020 1:13 pm    Post subject: Reply with quote
I got Morel at front which actually fitted under the old grille but went with the new ones (looks almost identical). At the back I have JBL GTO, ditto look.
https://www.tobesetc.com/Interior/
993 C4, Coupe '94 manual
Previous - '03 986 Boxster S
Photos at TobesEtc.com (work in progress)
Gwsinc
PostPosted: Thu Feb 13, 2020 3:45 pm    Post subject: Reply with quote
Received and fitted some Alpine coax speakers this week, there are some pics on my Instagram @gws911. I’m very impressed, and better than the B&O system in my Fiesta ST. The rears almost slot right in and all you need to do is shave a little plastic off the inside of the housing. The fronts slipped straight in. I also added a baffle behind the fronts to stop water getting to them.
£100 all in which isn’t too bad for a full speaker set up that sounds great and looks stock.
Alpine SPG-17C2 2-Way Co-axial Speakers https://www.amazon.co.uk/dp/B003H6XUA6/ref=cm_sw_r_cp_api_i_b4wrEbDPCYTVN
Alpine SXE 4625 S Car Loudspeaker https://www.amazon.co.uk/dp/B00011FW0Q?ref=ppx_pop_mob_ap_share
Pretzel
PostPosted: Thu Feb 13, 2020 10:29 pm    Post subject: Reply with quote
Did you keep the original tweeters?
993 C2 Aventura
Gwsinc
PostPosted: Sat Feb 15, 2020 1:09 pm    Post subject: Reply with quote
The new coax speakers effectively have tweeters mounted inside them so I removed MB Quart tweeters and didn’t replace them. I’ve ordered a 65mm plastic disc to cover the hole this has left.
mashby
PostPosted: Sat Feb 15, 2020 7:13 pm    Post subject: Reply with quote
I've got the exact same speaker setup with Morel fronts & JBL rears. Sounds great combined with a Continental head unit thumbsup
1994 993 C2
1974 MGB GTV8 3.5
1980 MGB Roadster 1800 stage 3
Mike_993
PostPosted: Sat Feb 15, 2020 9:48 pm    Post subject: Reply with quote
Gather you can now buy new original rear and front speakers from Porsche for 993's. Pricey I believe and would be intersting to hear if any one has fitted them.
1995 993 C2.
