Front brakes are starting to bind very slightly.
If I jack the front wheels up I can feel them dragging slightly. if I push the round tab on the rear pad back gently it frees off but binds again when the brake is applied.
I fitted new disc, pads and damper plates last year using the old pins and spring. i didn't grease anything just fitted them clean and dry.
Whats the recommendations, dry or lathered in copper grease?
I've either got a sticking pad or a piston not retracting same on both sides.
Before I strip them down this weekend to check any tips on sticking pads or checking for free piston movement?
Its 2005 997 S
Its 2005 997 S
