997 : 2004- 60
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
SlowM
PostPosted: Sun Feb 02, 2020 9:29 am    Post subject: Carrera 4 low speed abs pulse Reply with quote
New member here saying hello Very Happy
I'm the proud owner of an immaculate 1999 60k miles c4 cabrio tiptronic
The car itself drives perfectly apart from a niggling slow speed (10mph and less) gentle abs pulse? (I'm guessing this as the brake pedal pulses along with a twanging sound from the brake pedal area)
The car has been fitted with new abs sensors and the reluctor rings seem fine so a question to the 911uk members ....what's next to check, and who to visit for repairs I'm in north east London so any recommendations would be greatly received!
PostPosted: Sun Feb 02, 2020 9:36 am    Post subject: Reply with quote
Welcome
SlowM
PostPosted: Sun Feb 02, 2020 10:14 am    Post subject: Reply with quote
Thank you hsc911
Update! Just pulled abs fuse and the pulsing stopped definitely an abs issue
PostPosted: Sun Feb 02, 2020 10:42 am    Post subject: Reply with quote
Hello & welcome. Mines recently started doing the exact same at around 18mph. I'm guessing its an incorrect reading from one of the sensors. My plan when I get chance was to put the car on axle stands, remove the wheels and let the the car run in gear. Yes I know this will instantly chuck up a psm fault as the axles will run in opposite directions due to the diffs, but I plan to independently take a reading from each sensor and check for any discrepancy.
deckster
PostPosted: Sun Feb 02, 2020 2:10 pm    Post subject: Reply with quote
Bear in mind that everything I know about the internals of my car can be written on the back of a postage stamp in 14 point text - but my C4 did this from when I bought it; Northway traced it to a split collar (? - my recollection, not necessarily their words) on the driveshaft and recommended I replace the whole thing. With a new driveshaft on the pulsing went away and hasn't come back since.
Potentially a sledgehammer to crack a nut? But it worked and I was happy Smile
kurlykris
PostPosted: Sun Feb 02, 2020 2:50 pm    Post subject: Reply with quote
This was covered recently here Thumb
http://911uk.com/viewtopic.php?t=131931&postdays=0&postorder=asc&highlight=abs&start=0
2006 987.1 Boxster S 3.2 sport chrono
2010 Mercedes E350 AMG Sport
SlowM
PostPosted: Sun Feb 02, 2020 3:40 pm    Post subject: Reply with quote
Thanks for all the help and advice, much appreciated.
I shall dig my screw driver and handsaw out and take a look when I have dome spare time Thumb
PostPosted: Sun Feb 02, 2020 5:45 pm    Post subject: Reply with quote
I've revised my opinion of the cause since that post i'm afraid .. 996 and the rear driveshaft reluctor rings get corroded and the gaps will fill in with rust basically .. at slow speeds the car struggles to see these gaps and so activates the abs .
Sensor is possible but a very good look at all 4 reluctor rings is advisable ...
Lets just say i've seen 4 in the last 5 months all doing this .
Indy Mechanic .
SlowM
PostPosted: Sun Feb 02, 2020 7:43 pm    Post subject: Reply with quote
Again thanks for the all the replys,
So are the reluctor rings visable without taking the abs sensors out?? I.e. underneath the brake discs/hub etc ...Ta!
JS1500
PostPosted: Sun Feb 02, 2020 8:29 pm    Post subject: Reply with quote
I had this same issue. I bought 4x reluctor rings but only replaced the rears. I still have the other two if you want them - no charge.
2000 996 C4 - Guards Red
PostPosted: Sun Feb 02, 2020 8:58 pm    Post subject: Reply with quote
you can just about see them .. you are looking for a decent gap between each ring on each wheel .. rust joining the gaps together will make the car think the wheel isn't moving as it can see the other wheels moving and so decides that wheel is locked up .
Basically .. a gap then a solid then a gap tells the car that wheel is moving .. if it sees something different on a wheel ( due to corrosion ) then it assumes that wheel has locked up and so applies the abs ... a lack of gaps .
Front or rear can cause this with the last few i have seen all being rear .
Edit .. there should or at least might be a fault code .. if not an actual value a check on a tester will indicate which one is at fault .. for me .. i tend to spot the problem whilst its on a ramp .. perhaps a good inspection via an indy with this knowledge might help .
Indy Mechanic .
SlowM
PostPosted: Tue Feb 04, 2020 11:35 am    Post subject: Reply with quote
Update!
So wheels off today, rear, reluctor rings look new, like the after market ones along with new abs sensors, fronts mmm hour to get the sensor out.......passenger side reluctor ring rotted away/broken and same on drivers side, so off to the garage it goes!
Thanks for all the help..
UncleP
PostPosted: Tue Feb 04, 2020 2:35 pm    Post subject: Reply with quote
I'd been getting a little kick through the pedal. The garage I bought the car from actually experienced the issue and replaced all 4 ABS sensors and the ABS pump (not cheap, thankfully they paid).
On my winter tear down I noticed the front driver side reluctor ring looks like it's made of weetabix while the other 3 look like new. I'm going to guess that was the issue all along.
PostPosted: Tue Feb 04, 2020 8:36 pm    Post subject: Reply with quote
To both the above .. yup .. thats what ive seen recently .. corroded reluctor rings .. it's not senors .. its rusty rings basically .
Cars are getting older i'm afraid and new faults are appearing .. this is just the latest .
To understand it .. it's an on off switch .. 1010101010101 .. with a corroded ring you get 1110101010111 etc .. the car thinks a wheel has locked up .
At faster speeds and it kinda misses the 111 .. it looks at the other wheels and sees this is not accurate .
Indy Mechanic .
