997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
villaman
PostPosted: Sat Feb 01, 2020 6:38 pm    Post subject: Horn beeps on Ignition off Reply with quote
I fitted a new steering wheel and head unit over the winter and took the car for its first drive today since October and post them being fitted.
I did not notice this when i was fitting the above in the garage as i did put the ignition on having a play.
Ok..so thats the back story...and may well have nothing to do with it..but i thought i'd mention it
when i turn the ignition from Full on to Part off (not fully ignition off) the car horn beeps once.
It does not do it when i lock the car...which i know it will do if your lights are on or frunk is open.....
Any idea's ?
986 Boxster S Speed Yellow
987 Boxster Artic Silver
987 Boxster S Basalt Black / Red Roof
997 911 C2S Basalt Black (Current)
Newbe
PostPosted: Sat Feb 01, 2020 6:50 pm    Post subject: Reply with quote
I had a similar issue when I didn’t fit the airbag in right on the steering wheel. Took it out and refitted. All ok now.
PostPosted: Sat Feb 01, 2020 6:59 pm    Post subject: Reply with quote
I'm afraid all i can say is go with what Newbe has said .. unlike the 996 there is no alarm horn so it's nothing to do with the alarm system but the actual horn system itself .
Indy Mechanic .
villaman
PostPosted: Sat Feb 01, 2020 9:59 pm    Post subject: Reply with quote
Thanks guys ..I've just removed the airbag again , a couple of times, to no avail .
I think this might need coding out....
Newbe
PostPosted: Sat Feb 01, 2020 10:29 pm    Post subject: Reply with quote
What happens with the airbag out?.
If you have a diagnostic tool you could even unplug it to eliminate. Then use the tool to reset your air bag light?
villaman
PostPosted: Sat Feb 01, 2020 10:42 pm    Post subject: Reply with quote
Had thought about removing the airbag..good idea....
