997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
C11BRA
PostPosted: Sat Feb 01, 2020 12:13 am    Post subject: Now I have an X pipe, do I need to swap over the O2 sensors? Reply with quote
Hiya.
Just had a thought. Do I need to swap over the Post cat O2 sensor connectors now I have an X pipe?
Originally. Bank 1 exhaust pre cat O2 sensor would connect to N/S chassis plug. And bank 1 post cat sensor would connect to the O/S chassis plug.
However, now I have the X pipe. The bank 1 post cat sensor is now nearer the N/S. (in theory). Or do the gases still cross over at the X junction?
These sketches might help?
Top pick shows the factory O2 sensor connections.
Where do the gases go?
2006 997.1. Project GT3C. C stands for ???
2018 Audi A4 Avant Black Edition.
Ex 996 C2 Man.
Ex Ram Cobra V8.
Ex Series 1 RS Turbo.
Ronyted
PostPosted: Sat Feb 01, 2020 4:56 pm    Post subject: Reply with quote
Hi have a look at this https://youtu.be/kjo9MWSpuZA
a demo from fabspeed.
PostPosted: Sat Feb 01, 2020 7:02 pm    Post subject: Reply with quote
The sensors stay the same side .. they are to monitor the gases before and after the cat so they are fitted the same as pre X pipe installation .
Bank 1 pre and post should both connect to the n/s/r with B2 the o/s/r .. i dont understand if you are saying it was different .. it shouldn't be .
Indy Mechanic .
C11BRA
PostPosted: Sun Feb 02, 2020 12:19 am    Post subject: Reply with quote
My car had cat bypass pipes. Bank 1 pre cat sensor was close to the NS. However, the bank 1 post cat sensor was close to the silencer joint on the OS. I didn’t take photos but I seem to remember it being plugged into the OS chassis plug. Because it was closer. I’m not even sure it would reach the NS.
I’ll put some photos up tomorrow.
Ex 996 C2 Man.
Ex Ram Cobra V8.
C11BRA
PostPosted: Sun Feb 02, 2020 2:34 am    Post subject: Reply with quote
This might explain my worries.
Ex 996 C2 Man.
Ex Ram Cobra V8.
Magic919
PostPosted: Sun Feb 02, 2020 7:50 am    Post subject: Reply with quote
I wouldn’t worry about it. If you ever get post cat sensor alarms, just bear in mind where each is located.
997.2 C4S PDK
C11BRA
PostPosted: Sun Feb 02, 2020 10:55 am    Post subject: Reply with quote
The car was running super rich. And all 4 sensors would be stored as faults after 2 or 3 drives. Check engine light would come on.
It did have the post cat O2 sensor extensions to weaken the results. And a re-map apparently. But the light would still come on.
Maybe it’s a blessing that I didn’t take notes of which sensor wires went where. Because if they were wrong, they would still be wrong.
De Mort says both Bank 1 sensors plug into the NS chassis plug. So that’s how it’s gone back together.
Let’s see what the lights do.
Ex 996 C2 Man.
Ex Ram Cobra V8.
C11BRA
PostPosted: Sun Feb 02, 2020 11:18 am    Post subject: Reply with quote
I think it was plugged in wrong before. Satisfying to know it’s correct now.
I sent you a PM De Mort. But all my PMs are stuck in my outbox and won’t send. Any clues why?
Ex 996 C2 Man.
Ex Ram Cobra V8.
PostPosted: Sun Feb 02, 2020 5:09 pm    Post subject: Reply with quote
Pm,s are stored in your outbox until the recipient logs on and reads them .. i'm only here in the evenings so i have just got yours Smile
It seems to me it was originally wrong but a swopped post cat sensor side to side won't make any difference .. all it will do is throw a fault code for the wrong bank in the event of a cat or post cat sensor failing .
Pre cats swopped is a much bigger deal .. the car will run bad and log fault codes / eml pretty quick.
Running rich can be caused by various things but Maf and Lambda sensors are the more common causes .
EDIT ..
Post cat sensors are there to monitor the condition of the cat Only .. they have no effect on the running of the car.
Indy Mechanic .
PostPosted: Mon Feb 03, 2020 6:51 pm    Post subject: Reply with quote
This has been bugging me today .. i don't like the fact you had all 4 lambda fault codes ..
I would be interested to know what the codes are though .
i was thinking .. is it possible the lambda sensors have been mixed up and the post cat has had the pre cat sensor fitted .. that would certainly cause issues .
A couple of images below ..
The Grey plug sensor should be fitted into the post cat hole .. so it's the after cat sensor .
The Black plug Sensor should be fitted in the pre cat hole .
As you can see these are the bank 1 sensors and both fitted to the n/s/r .
Indy Mechanic .
 Filesize:  476.73 KB
 Viewed:  392 Time(s)
 Filesize:  537.31 KB
 Viewed:  392 Time(s)
