997 : 2004- 63
Boxster : 1997- 25
Cayman : 2005- 20
Macan : 2014- 3
cvega
PostPosted: Sun Jan 26, 2020 4:48 pm    Post subject: fuse tap question Reply with quote
hey folks,
going to add a circuit to my 996 using one of the commonly available fuse taps, i've been poking the fuses and my current fuse/circuit of choice is windscreen wipers (c6), a few questions;
- i'm going to use a fuse tap with 2 fuse holder, and a 12v-5v dc to dc converter with 2 usb outputs (one for dashcam, one for a phone charging lead).
- which side of the fuse holder in the 996 is hot?
- can anyone share how htey installed it?
- there are multiple unused fuse slots in my car for options that it doesn't have, with 1 connector inside the slot rather than 2. I assume i shouldn't use one of those?
Any advice welcome, trying to make sure i don't blow things up / set the car on fire
2003 996 C2 (Ohlins R&T suspension, Toyosport/Spyder exhaust)
MisterCorn
2004 Porsche 996 Turbo
PostPosted: Sun Jan 26, 2020 5:01 pm    Post subject: Reply with quote
There are proper connector blocks in the relay board for power distribution. If you don't need a separate fuse for the item I would go from here, much neater.
MisterCorn
PostPosted: Sun Jan 26, 2020 5:05 pm    Post subject: Reply with quote
If you do need a fuse, why not just use an unused slot in the fuse board. Might just be me, but I really don't like 'bodges' like this.
cvega
PostPosted: Sun Jan 26, 2020 8:49 pm    Post subject: Reply with quote
Hmm... which board?
I would prefer a fuse, just in case.
