997 : 2004- 58
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
Giff
PostPosted: Sat Jan 25, 2020 8:51 pm    Post subject: Front ARB drop link - pain in the.. Reply with quote
Evening.
I'm not having fun trying to replace the front ARB drop link, the long threaded piece that also holds the shock to the hub will not come out.
The whole assembly is now on my bench, any tips?
Cheers.
997.2 C2
golfprorich
PostPosted: Sat Jan 25, 2020 9:50 pm    Post subject: Reply with quote
Lots of heat then a decent impact gun ***** between forward and reverse while whacking the other end of the bolt. Had fun before with one of these on a Boxster frustrated
Cayenne S 4.5 V8
golfprorich
PostPosted: Sat Jan 25, 2020 9:51 pm    Post subject: Reply with quote
I didn't use a swear word either above Question
Cayenne S 4.5 V8
D5RSR
PostPosted: Thu Jan 30, 2020 9:23 am    Post subject: Bolt Reply with quote
Had the same issue on Boxsters not tried my 997 yet, but I ended up cutting the ball joint off using angle grinder and getting a spanner/ socket on the bits that's left to try and get movement, you'll see flat edges just under the joint.
Eventually they come out and don't look too corroded but they we're a right *** to get out.
Good luck, and keep hammering.
PB Blaster may help.
Darren
997.1 C2S
Leeds
RXP.
PostPosted: Mon Feb 03, 2020 11:26 am    Post subject: Reply with quote
alloy and steel and water dont mix well bud.
3 words, heat, heat and more heat. localised.
Good luck
Giff
PostPosted: Mon Feb 03, 2020 11:45 am    Post subject: Reply with quote
This reminds me too much of my short spell with an S2000, suspension bolts assembled dry and a nightmare to remove.
Finally completed the job but had to completely dissemble the suspension..
997.2 C2
 Filesize:  1.66 MB
 Viewed:  385 Time(s)
Shalmaneser
PostPosted: Mon Feb 03, 2020 1:16 pm    Post subject: Reply with quote
I'm currently in the middle of this nightmare on my girlfriends 987. Any wise words from those who have gone before? Did you split the hub from the coffin arm or just unbolt the coffin arm? Was that a PITA too?
205 GTI 2.0 16V - BMW E36 M3 Evo - BMW E46 M3 - Porsche 996 C2
wasz
Paul Ricard
1999 Porsche 996 Carrera 2
PostPosted: Mon Feb 03, 2020 4:50 pm    Post subject: Reply with quote
get someone else to do it Floor
996 parts cache sell off
Giff
PostPosted: Mon Feb 03, 2020 5:20 pm    Post subject: Reply with quote
Loosen the coffin arm to chassis bolt and it will allow the assembly to drop down significantly further making the job a lot easier, you can then undo the hub ball joint quite easily to move the job to the bench.
997.2 C2
