997 : 2004- 61
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayenne : 2003- 7
Spicy9114S
PostPosted: Sat Jan 25, 2020 1:06 pm    Post subject: Wanted :- 997 carbon hand brake Reply with quote
Hello
I know it's a long shoot but I was wondering if anyone had a carbon handbrake lever for a 997 laying around that they wanted to sell?
Thanks for looking
Steve
NedHan79
PostPosted: Sat Jan 25, 2020 6:41 pm    Post subject: Reply with quote
I have a 996 carbon tequipement one that I have for sale. Not sure if they’re the same or not
#modified996mk1
 Filesize:  1.74 MB
 Viewed:  799 Time(s)
Spicy9114S
PostPosted: Sun Jan 26, 2020 9:01 am    Post subject: Reply with quote
Hello
I've been told the 996 handbrake doesn't fit the 997.
Thanks for posting though.
PostPosted: Sun Jan 26, 2020 3:18 pm    Post subject: Reply with quote
Options for OE
https://www.ebay.co.uk/itm/143315300315
or aftermarket
https://www.supertweaks.com/porsche/porsche-carbon-fibre/porsche-997gen1-carbon-fibre/porsche-carrera-997-gen-1-2-carbon-fibre-hand-brake
Spicy9114S
PostPosted: Sun Jan 26, 2020 6:03 pm    Post subject: Reply with quote
I did see that one on eBay but I need a black leather and carbon one, not sure how easy it will be to separate the carbon outer section off to swap it over.
Thanks for looking Smile
PostPosted: Sun Jan 26, 2020 8:10 pm    Post subject: Reply with quote
They are not easy to separate and believe me I tried, they are supposed to be glued on but you can twist off, when I could hear cracking I stopped lol......ended up swapping the whole lever over which is pretty easy but I'm used to removing and refitting the centre console.
Spicy9114S
PostPosted: Sun Jan 26, 2020 9:58 pm    Post subject: Reply with quote
Yeah I thought as much. Carbon and glue tends to lead to a very permanent join :-(
Pity that one on eBay is res
tgdesign
2006 Porsche 997 Turbo
PostPosted: Mon Jan 27, 2020 10:32 am    Post subject: Reply with quote
Change over the leather part. that's quite easy
PostPosted: Mon Jan 27, 2020 8:37 pm    Post subject: Reply with quote
True the leather is easy to swap over ......means you could get a none black leather one .......but you'll still need to swap the levers over Thumb
PostPosted: Tue Jan 28, 2020 2:59 pm    Post subject: Reply with quote
Changing the hand break over is not major just a bit time consuming mines been in and out loads of times lol. and you can reuse your black leather rear banana section they just slide off. that would be what I would do. Thumb any Indi would do it no problem Thumb
Robertb
2002 Porsche 996 Carrera 4S
PostPosted: Tue Jan 28, 2020 3:11 pm    Post subject: Reply with quote
I'd have thought re-dying the leather would be pretty straightforward... need an airbrush and some leather dye.
tgdesign
PostPosted: Tue Jan 28, 2020 6:35 pm    Post subject: Reply with quote
I have a rear black leather part I can sell.
If you buy the one off ebay
Thumb Thumb Thumb
