997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
jkhamler
PostPosted: Fri Jan 24, 2020 6:33 pm    Post subject: Frunk Size 997.2 C2 Reply with quote
Hello all,
I am gradually accumulating the funds I need to buy my dream car - a Gen 2 997 Carrera.
In the meantime it would be very interesting to know the largest cuboid item that can fit comfortably. It would be my only vehicle and thus it would have to serve the function of function band tour bus (a small PA system and bass gear must fit inside somehow - a roof rack will probably come into play too)
Would it fit a speaker 44cm x 38cm x 43cm?
Jon
pzero
PostPosted: Fri Jan 24, 2020 7:01 pm    Post subject: Reply with quote
http://www.911uk.com/viewtopic.php?t=120339&sid=cc38f0f8efa9d5c5d6191ea8c2315b56
You may be lucky, just don't buy a GTS, Turbo or 4S. They all have a slightly smaller boot space than the Carrera S. Your main issue will be the fairly square shape.
The pink case in the example above was a very snug fit.
991.1 Carrera GTS
Captain Lockheed
PostPosted: Fri Jan 24, 2020 9:13 pm    Post subject: Reply with quote
You are not American, it is called a froot. Front Boot
Saving for a 993.
jkhamler
PostPosted: Fri Jan 24, 2020 10:13 pm    Post subject: Reply with quote
Haha great. I stand corrected. Looks like the froot might be just big enough, excellent!
PostPosted: Fri Jan 24, 2020 10:18 pm    Post subject: Reply with quote
It has been debated before and I think you'll find that there's a lot more 911ukers that refer to it as the frunk rather than the froot.
A quick google search seems to point to 'froot' being more of an Australianism.
Captain Lockheed
PostPosted: Sat Jan 25, 2020 11:18 pm    Post subject: Reply with quote
Lot’s of people being wrong👎, doesn’t make them right.👍
Saving for a 993.
FZP
Estoril
PostPosted: Sun Jan 26, 2020 3:14 am    Post subject: Reply with quote
God's English 🇦🇺🇦🇺🇦🇺🇦🇺🇦🇺🇦🇺🇦🇺🇦🇺
Happy Australia Day to all
Thank God it's cooled down
Only 36° at the moment Bandit Heat Heat Heat
GlenB
PostPosted: Sun Jan 26, 2020 8:31 am    Post subject: Reply with quote
I hadn't actually heard froot till now, but it makes much more sense and should be promoted thumbsup Thumb Judge
