997 : 2004- 57
Carrera SC : 1977-1983 3
Boxster : 1997- 27
Cayman : 2005- 22
Cayenne : 2003- 7
Lee997
PostPosted: Fri Jan 24, 2020 5:53 pm    Post subject: 997.1 key fob batteries? Reply with quote
Hi all, preventative maintenance only, thought it pruden5 to swap out batteries in fobs as car battery is being taken care of with a Ctek.
I haven’t looked but thought I’d ask, I’m assuming they take the typical CR2032, or red they more exotic?
How do the fobs come apart to access? Is there any special sequence or will they re associate with the car when used ?
Thanks in advance.
PostPosted: Fri Jan 24, 2020 7:03 pm    Post subject: Reply with quote
You are correct on the battery ..CR2032 ..
Link to opening them .. pretty easy ..
https://www.google.com/search?q=997+key+bsattery+replacement&rlz
There isn't normally an issue but on the off chance the remote stops working then put the key into the ignition lock and turn to ignition on .. press and hold a key fob button for 5 seconds .. this will teach the fob to the car .
Indy Mechanic .
Lee997
PostPosted: Sat Jan 25, 2020 1:00 pm    Post subject: Reply with quote
Cheers Iian, that was easy wasn’t it! I’ll get some ordered up and change them out!
Lee.
